Old 05-04-2016, 09:07 AM   #11
wicked1's Avatar
That is water or moisture had it in my Shasta had to replace the wall area and have the roof and gutters resealed it was leaking in under the gutter from what a Shasta dealer told me, did not damage the wood so we were lucky
2016 F350 SCREW SB 6.7 PS Diesel
2015 FR Rockwood Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 05-04-2016, 09:09 AM   #12
lesptr's Avatar
Thanks for the info. I'll be home this weekend to hopefully get it taken care of.
Sent from my iPad using Tapatalk
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is online now   Reply With Quote
Old 05-06-2016, 08:14 AM   #13
mrpep's Avatar
Caulk the heck out of anything and everything , I'm not trying to make pretty anymore, I'm trying to protect the trailer is all.
mrpep is offline   Reply With Quote
Old 05-06-2016, 08:19 AM   #14
Flybob's Avatar
Check the side marker lights. Many times they are not sealed well and water will travel along the wiring once it gets inside.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-06-2016, 08:22 AM   #15
mrpep's Avatar
I have a spot like that too and the only thing that makes me feel some conform is that it is very hard so the integrity of the wood is still there. If your wood is soft , really soft then you may have a bigger problem. If your gutsy , pull off some paper if the wood is soft and if it is wet and soft than you have a problem that needs fixing , if the wall is soft but completely dry than its an old problem that was stopped and may be able to wait.
Old 05-07-2016, 12:04 PM   #16
lesptr's Avatar
Blistered wallpaper?
Update: we've been cleaning and inspecting the roof and walls where the gutter, awning, and porch lights attach. This is what we have found that raises our suspicions.
There is a screw through the awning where it attaches to the gutter presumably to keep it from sliding fore and aft in the rail.
I'll cover that screw with proflex.
I pulled the plastic wire covers from the awning attachment and found this.
The top right quadrant of that hole has no sealant at all. It is where the worst part of the wallpaper blisters are, but the hole is near the bottom of the wall. I know water can flow upward through capillary action, but can it flow upwards of 5 feet or more?
We also noticed where the wires go through the wall for the led strip under the awning is poorly sealed.
I don't believe this is a cause of any damage though as it is on the other side of the door. It too will get some proflex.
My question is, what should I use to insure a good seal of the gutter to the roof. This is what I have on hand.
Do I need something else?
Thanks again
Les
2015 F350 6.7
Old 05-07-2016, 01:12 PM   #17
mrpep's Avatar
Lap sealant is soft and has self level ability so don't use vertically , use the proflex for verticals. There's also Dicor clay tape that is used when putting on trim or anything that gets screwed down .
Old 05-07-2016, 01:45 PM   #18
lesptr's Avatar
Just to be sure, it IS ok to use proflex on the roof membrane?
2015 F350 6.7
Old 05-07-2016, 01:47 PM   #19
mrpep's Avatar
From what I have been told you don't wanna use proflex on roof - use the lap sealant .
Old 05-07-2016, 02:20 PM   #20
Dicor makes a lap sealant that is not self leveling called non sag.....thats what you use for roof to awning or gutter rail.
In addition to flybobs comments about marker lights, not sure how coachmen does it but on our new Rockwood they do not caulk them......they use a closed cell foam gasket. I pulled 3 after a rain and found water behind all 3. For gaskets to work screws need to be tight and not stripped. I ordered geocel so I can caulk all the lights, windows, and everything else. Pay 20 K for a trailer and then finish building it.
Why did you post Rudys picture lol. He's one creepy dude that Rudy.
Mr Havercamp is offline   Reply With Quote
