Old 09-07-2013, 07:26 PM   #1
glj104's Avatar
Brand new apex 201qbv
Should the lights in the slide out work off the battery? All the other lights do except that one. I haven't hooked it up to a 30 amp plug to know if it only works off the hook up. Thanks. Glenn
glj104 is offline   Reply With Quote
Old 09-09-2013, 09:22 AM   #2
bradnailer's Avatar
Generally, all interior lights run off 12 volt. May have a bad connection or bulb.
2016 Ford F150 Platinum
2013 Coachmen Freedom Express 233RBS
Prior: Jayco Pop Up, Shasta Bunkhouse, Rockwood 2560G Pop Up
bradnailer is offline   Reply With Quote
Old 09-09-2013, 09:28 AM   #3
glj104's Avatar
Any idea on how to check the connection?
Old 09-09-2013, 03:42 PM   #4
bradnailer's Avatar
First pull the lenses and check the bulbs. If they are OK then you probably would need to unscrew the fixture and check the wires coming to the fixture. If they look secure then take a multimeter or a test light and see if you have power to the fixture. If you don't have juice to the fixture, chances are you have a cut wire between the fixture and the panel or maybe that fixture wasn't hooked up originally.
Old 09-09-2013, 03:44 PM   #5
glj104's Avatar
awesome. I will try that tonight.
Old 09-11-2013, 07:46 PM   #6
Ford Idaho's Avatar
Did you check the fuse yet
Old 09-11-2013, 07:50 PM   #7
glj104's Avatar
Fuse is fine. I will try to switch with a different fixture this weekend. Let you know then.
