Old 12-30-2018, 12:23 PM   #1
buskirk21921's Avatar
Broken Spring hanger
After our last trip of the season and upon pulling into the driveway I heard a metallic pop and upon stopping noticed that the spring hanger for the rear axle, drivers side had broken only leaving the base plate. I called Lippert(LCI) and they sent me the bracket and hardware. I have since had a welder, weld the new bracket in place. I have a 2015 according to title(2014 mfg. date) 360IBL Coachmen Chaparral. I would suggest getting a flashlight and checking for any cracks in the hangers.
Name:	Spring Bracket VI.jpg
Name:	Spring Bracket IV.jpg
Name:	Spring Bracket VII.jpg
Joe and Diane Buskirk
2015 Chevrolet Silverado 3500HD Duramax Diesel 4x4 SWD
2015 360IBL Coachmen 5th Wheel
"Camping is not just a past time it is my relaxing way of life"
buskirk21921 is offline   Reply With Quote
Old 12-30-2018, 01:22 PM   #2
Thanks for the heads up.
A good reminder for everyone to periodically look at things you would think would last forever.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 12-31-2018, 04:37 PM   #3
Thanks for the post. I was just installing never fail bushings on my 360IBL a few weeks ago and wondered if the hangers ever break off. Lord knows I beat them hard enough.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition
2018 Chaparral 360IBL w/Andersen Ultimate 2, Tireminder SMART TPMS, Swift Hitch SH04 WiFi Backup/Rear View Camera, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 12-31-2018, 05:01 PM   #4
Where did you purchase the No Fail Bushings and what size did you purchase? Thanks.
Old 12-31-2018, 05:10 PM   #5
I got this kit. Lippert 281285 Never Fail Shackle and Bolt Kit for Double Axle https://www.amazon.com/dp/B00BFUA9TQ..._lnPkCbBEVNWNV I should have gotten just the bushings only kit since I am planning on installing the correct track alignment/lift kit.
The bushing-only kit is $55
Old 12-31-2018, 05:32 PM   #6
Thank you.
Old 02-09-2019, 01:24 PM   #7
I keep seeing this name "LIPPERT" who are they? And what do they do?
Lee Pedrick is offline   Reply With Quote
Old 02-09-2019, 01:33 PM   #8
They make the Chassis, slide mechanisms and many more items. See their website. They are the major and in some cases only supplier for these types of components to the RV industry.
https://www.lci1.com/
Old 02-10-2019, 08:45 AM   #9
Also they make Ground Control 3.0 auto-leveling system which I am currently in the process of installing on my 360IBL
Old 02-11-2019, 01:37 AM   #10
I am adding braces across the trailer to strengthen the spring hangers. This is an all too common problem with Lippert frames. Seems to be a bigger issue on spread axles.
I installed the greasable Morryde shackle and bolt kit.
2017 Coachmen 233RBS
2018 Ford F150 Lariat
"Common sense is not very common"
babock is online now   Reply With Quote
