Old 05-15-2019, 06:58 PM   #1
Brookstone 310RL Converter
Does anyone know where they mounted the WFCO converter. I would think it would be near the battery and inverter but it is not there.
The inverter is a WF5110 true sine wave and I don't think it has a built in converter.
msstefanski is offline   Reply With Quote
Old 05-16-2019, 09:35 AM   #2
My converter is a good bit away from the battery but it is relatively close to the 12v/120v distribution panel. My converter is located under the interior stairs. On my rig, if you turn all the 12v lights on you can hear the converter cooling fan kick on. That might help you find it.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 05-19-2019, 11:41 PM   #3
Retired Old Fart
dward51's Avatar
Should be in the breaker/fuse panel which is at the bottom of the cabinet directly in front of the entry door. Right below the other control switches (other switches are in the upper cabinets). The front of that brown plastic panel flips down and the converter is in the bottom of that if it's a WFCO. You may have to unscrew the panel beneath the flip down panel to actually see the converter assembly.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
converter, roo
