Old 12-12-2017, 09:53 AM   #1
Bunk ladder (360IBL)
Got on the ladder in my bare feet for the first time this weekend. OUCH that was painful. The rungs are designed for the ladder to be used straight vertically while the ladder mounting h/w is designed for a 45deg(ish) slant. Result is a the corner of a metal rung digging in your feet.
I see ladders on Amazon designed for the rungs to be flat when the ladder is at 45deg (ish). $60. That would be cheaper than making wood overlays for each rung to change the angle.
Any of you experience this with your setups? How did you remedy?
2016 RAM 3500 DRW 4x4 LB LoneStar Edition
2018 Chaparral 360IBL w/Andersen Ultimate 2, Tireminder SMART TPMS, Swift Hitch SH04 WiFi Backup/Rear View Camera, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 12-12-2017, 10:16 AM   #2
Fulltime family RVer
I bought a bunk bed ladder from Amazon. Itís a wider step that is flat at an angle.
My father-in-law made one for his trailer for a fraction of the cost.
Well worth the upgrade!
Old 12-12-2017, 12:17 PM   #3
Saturn V's Avatar
Yeah the factory ladder is painful. We don't use it since my son is able to get up there without a ladder.
2018 Coachmen Chaparral 360IBL
2008 Ford F250, V10, 4.30
Saturn V is online now   Reply With Quote
Old 12-19-2017, 09:50 PM   #4
Figured out the ladder was at the wrong angle. The dealer had over-the-bunk hooks on the ladder connected to the vertical surface mounted clips. This put the ladder base too far from the bed. Removed the clips to force users to hook it over the bunk frame.
http://www.explosivepowersports.com/...RoCsFwQAvD_BwE
bunk
