Old 08-21-2019, 11:37 AM   #1
bunkhouse size/axles vs Azdel
After a ton of research, I've found that my ultimate TT would be the Nano 208BHS. Unfortunately, it is too much TT for my 2013 Jeep Grand Cherokee to pull. So my next choice is the smaller version, 193BHS. Aside from weight, I figure I'm settling on single size bunks and 1 axle while maintain the same build quality and Azdel walls.
For those that have gone through similar floor plan decisions, would you put Azdel walls and build quality over a similar floor plan with 2 axles and double size bunks?
I just found Forest River Salem FSX 178BHS last night, which have the double bunks and 2 axles while staying within my weight requirements. Just not sure if that is comparable to an Apex Nano quality-wise.
HotBacon is offline   Reply With Quote
Old 08-21-2019, 12:57 PM   #2
bikendan's Avatar
Isn't the Nano aluminum frame/fiberglass siding vs the Salem's stick and tin construction? If so, there should be a big difference.
Equalizer WDH
axle, bunk, bunkhouse
