12-12-2016, 09:51 PM
#21
Hey sorry it took me so long to reply but Ive had a dam time just trying to log in anyway pkt up coach and its awesome! Had a few glitches like the radio/cd/dvd didnt work but I had them pull it out and ups me another new one and the bike/gen rack on back has too much play in the up position also the water inlet vave is new to me because you have to fill by hose but its all good and I sure am happy and so is the wife
12-12-2016, 09:52 PM
#22
Going out on first trip Saturday
12-28-2016, 06:21 AM
#23
First trip
How was the first trip? I remember mine, trying to figure what light switch turned what on, inside and out. You will find that each time you go, you will want to purchase a few things. When I had my travel trailer I didn't have a hose hookup on RV to flush my toilet tank so I got this from Amazon.
Camco 39062 Dual Flush Pro Holding Tank Rinser with Gate Valve.
I still use it to see that the water is clear when back flushing. Also You may want to get extra sewer hose , I was at a camp site last week and the connection in the ground was far. Luckily I had a short extension hose and just made it, SO I'm going to purchase additional 15 ft hose. Anyway hope your first camping trip was a good one. Enjoy!
01-06-2017, 01:17 PM
#24
Originally Posted by Resurrected1
water leak from ice maker tubing, lock on the front compartment doesn't work. Opening is too big and the latch on the lock has nothing to "catch".
We've had these 2 same issues. Pretty good leak from the icemaker tubing. Super easy fix once we discovered the issue. I took a longer piece of metal and made a new latch for the front storage door problem.
Same unit as yours. same problems. go figure.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
01-06-2017, 10:52 PM
#25
Hey my floor registers for the heater barely blow in the kitchen area and the living area but will blow u out of thr bedroom and bathroom got any ideas?
01-06-2017, 10:57 PM
#26
Hey thanks to everyone this is a great forum lots of info
anyway been on a few trips with the usual little problems but still having a great time hope to some of yall some time out on the road👍
01-07-2017, 06:47 AM
#27
We had the same issue... we installed vent covers with adjustable louvers in the rooms with too much heat... not 100% but much better
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
01-07-2017, 10:47 AM
#28
Hey thanks that migjt be the way to go
01-07-2017, 11:37 AM
#29
Same issue here and did the same thing with the adjustable registers. What really helped the most is I closed off some of the ducting going into the bedroom as well. Cut down on the air flow and pushed it down the line towards the living area. Much more comfortable in the front bedroom. No longer a walk in oven.
Dwayne and Susan
01-09-2017, 10:06 AM
#30
I was thinking of doing the same thing. I can't afford (time) for the dealer to have it for months. Our current house was only on the market for 3 days (in Aledo). We will, now, be living in this while we build a new house, on our property in Weatherford. I'm really hoping that nothing else goes wrong while we are living in it...
2017 Brookstone 395RL
2019 Ford F350 DRW w/Demco Hijacker Autoslide (carryover from my previous SB truck).
01-09-2017, 07:04 PM
#31
Vent flow
Dan
The heater box is under the floor in the bed-bath area on the 30rls, Behind the removable wall in the storage comp.The duct hoses are shorter coming out of the box to the bed and bath and much longer to the back end. I believe That's why the force is stronger in the front area . I had a problem with my heater box on my old travel trailer , the main board went bad and had to take it apart to change it,So was able to see how things were put together. It's pretty much the same with the AC I guess , cooler in the rear then the bed room. I would like to get a second AC unit for the bed room before next summer ,prep wiring is there but not much clearance under my carport to back in. Have a few Inches to spare once I disconnect. Since it is still under warranty, you may want to have them check the duct work for blockage.
02-16-2017, 11:36 AM
#32
Hey just got to your reply sorry it took so long and I am thining about doing just that. I posted something yesterday about the tv cable
