Old 03-31-2016, 12:50 PM   #1
Hoffwmn's Avatar
Can we use dinette with slide in?
I've recently read several places that walking on the slide floor or sitting in the slide when it is not extended can damage the alignment of the slide. We have a 2015 Coachmen Leprechaun 220QB. We frequently pull into a truck stop or rest area overnight and don't extend the slide with the dinette. Can we do damage sitting at the table with the slide in???
Hoffwmn is offline   Reply With Quote
Old 03-31-2016, 08:41 PM   #2
VizJedi's Avatar
Not sure what the "official" answer is, but I had my prior 5er for 13 years. It had a couch and dinette on the living room slide. We used it many times closed and DS liked to 'ride' on the couch when I put it in and out. Never had to have it realigned in 13 years.
j
2016 Coachmen Chaparral 390QSMB
2011 F350- CC, DRW, LB, PSD
2016 nights camped: 40
2017 nights camped: 16
2017 nights reserved: 30
VizJedi is offline   Reply With Quote
Old 03-31-2016, 08:46 PM   #3
RedLdr1's Avatar
Since the slides in motor homes often have seat belts for use while driving I think the answer is an easy No...you won't damage it.
Wayne and Christine
2020 Sunseeker MBS 2400Q Out For Full Body Paint 10/23/2019
RedLdr1 is offline   Reply With Quote
Old 04-01-2016, 08:33 PM   #4
World Wide Wanderer
wahoonc's Avatar
First I have ever heard of a slide being damaged by being used while it is in. I say no. I have had multiple units with slides over the years and have never had a problem using them in or out.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 04-02-2016, 11:32 AM   #5
Dabmeb's Avatar
In a travel trailer you should support the floor of the slide near the middle as it is raised a bit above the floor. Don't know if forest river has had problems but crossroads did. The floor would pull away from the bottom of the side walls if walked on while pulled in. We used to use two rubber door wedges under our superslide in a crossroads trailer we had because you had to walk thru the slide to get to the toilet while traveling
Dabmeb is offline   Reply With Quote
Old 04-02-2016, 11:47 AM   #6
We don't extend our slide when we stop for lunch at rest areas and have had no problems whatsoever. Also sit at the dinette occasionally while traveling.
SkipnTerri is offline   Reply With Quote
Old 04-02-2016, 12:11 PM   #7
Pathfinder75's Avatar
Have used dinette many times on our Leprechaun slide in. Would agree with seat belt answer making sense that they are intended to be used for seating when driving.
Could contact Coachmen to verify. I will continue using mine, its been four years now.
2017 Montana HC 353RL
2017 Ford F350 6.7L Dsl., CC, SWR, LB, B&W Companion #BWRVK3300 OEM Prep mtg.
PAST- 2012 Coachman Leprechaun 319DSF w/TOAD -2011 Chevrolet Equinox 4-cyl. AWD, 2008 Springdale 266RL, 2002 Outback 25FB
Pathfinder75 is online now   Reply With Quote
Old 04-02-2016, 12:11 PM   #8
In my TT the dinette slide is supported against the outer wall when in the "in" and "out" positions. So we sit on it when in the "in" position. When in motion there is no support except for the slide rails so I wouldn't sit on it while moving it in or out. Depending on how much weight is on it, it could bend the rails.
2013 Grey Wolf Select 28BH
2012 Ford F250 Lariet Super Duty 4X4
biker2 is offline   Reply With Quote
Old 04-02-2016, 12:57 PM   #9
I would have to agree. There is no point in wearing seat belts with the slide extended out. These slides are also on rollers to give the slide floor stability.
PenJoe is offline   Reply With Quote
Old 04-02-2016, 01:19 PM   #10
Gold Miner At Heart
Papa-t's Avatar
We have always used ours when we stop for lunch.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
Papa-t is offline   Reply With Quote
Old 04-02-2016, 03:44 PM   #11
oldsmasma's Avatar
We don't extend our slides for quick lunch stops and our 70 pound dog rides on the sofa most of the time. We've never had problems with any of our units.
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
oldsmasma is offline   Reply With Quote
Old 04-02-2016, 04:36 PM   #12
BobHanke's Avatar
As RedLdr1 says, "Since the slides in motor homes often have seat belts for use while driving I think the answer is an easy No...you won't damage it."
X2
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = NaNa & NiuNiu
BobHanke is offline   Reply With Quote
Old 04-02-2016, 04:40 PM   #13
Ford Idaho's Avatar
The only warning I have see said when the Slide Is In Do Not Step On The Edge of the slide it is NOT supported by anything.
Old 04-03-2016, 07:31 AM   #14
Wolverine 1945's Avatar
There was a person the other day that said they were looking @,,, I think a TT on a sales lot,,, and the salesman told them they should not sit on the sofa when the slid was in ??? I am guessing sofas in TTs do not have seatbelts !!!
Not sure what good a dinette would be if you could not use it when it was in ???
Wolverine 1945 is offline   Reply With Quote
Old 04-03-2016, 07:54 AM   #15
TsnTexas's Avatar
Makes sense on a motorhome since the seatbelts are there, but I'm wondering about a travel trailer? Had planned on occasionally sleeping on the slide for quick stopovers. We have a Rockwood MiniLite (2504s) with dinette slide.
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 04-03-2016, 09:26 AM   #16
If the same components and mechanisms are used in a MH or TT, it shouldn't make any difference.
Old 04-03-2016, 09:48 AM   #17
I believe the Slides in our Sunseeker are much different than the one we had in our old Flagstaff TT ???
Old 04-03-2016, 12:01 PM   #18
I call BS on what you've read or heard. We've done it with every unit we owned; no damage.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
slide
