Old 01-07-2017, 08:47 PM   #1
Can't tighten awning knobs 2016 283RKS Catalina
I have an electric awning on my 2016 283RKS Catalina. I can not tighten the knobs on my awning, so when it is out and it is raining one side drops allowing water to run off. I tried to removed them so I could drill a dimple in the arm to rest the knobs threaded end in to hold it, but I could not remove them. They appear to have a retaining washer on them. does anyone have a similar problem and how did you fix it.
ilcamphost is offline   Reply With Quote
Old 01-08-2017, 03:07 PM   #2
It's supposed to do that, when the weight of the water in the awning gets too much it dumps to one side.
If you want it to dump to the opposite end, loosen the knob on the other arm a bit.
2015/05/04 - 2016 Coachmen Freedom Express 310BHDS Maple Leaf Edition
YEGrolo is offline   Reply With Quote
Old 01-08-2017, 04:19 PM   #3
I can not tighten the knobs on my awning. They tighten not release within a few minutes. Need a method to tighten them.
Old 01-08-2017, 04:32 PM   #4
Are the threads stripped?
2017 Coachmen Catalina 283RKS
2004 Chevy Silverado 2500HD Crew Cab
Crabman is offline   Reply With Quote
Old 01-08-2017, 06:21 PM   #5
tapex's Avatar
Replacement knobs are at most anywhere that have Camping Supplies
2016 Coachmen Apex 250RLS Ultra Light
'19 Ram Big Horn Lonestar Sport
(3)yrs.=(865)Days
tapex is offline   Reply With Quote
Old 01-10-2017, 06:18 AM   #6
I understand what the OP is saying. I have the same problem with my W&P awning. I usually try to have one corner lower than the other but have a heck of a time getting the knob tight enough to hold that position. Mine turn just fine and the threads are free but it just doesn't apply enough clamping force to hold. I have decent grip in my hands so am pretty sure that someone with lesser hand strength would have even more of a problem. I haven't looked in to bigger knobs but would guess that would help a lot.
2017 Wolfpack 25Pack12
08 Dodge Cummins 6spd 4X4 CC
Papa Rich is offline   Reply With Quote
Old 01-10-2017, 06:28 AM   #7
Friction is your friend.
A fiber washer under the tension knob may help .
FFred is offline   Reply With Quote
Old 01-10-2017, 07:26 AM   #8
jeff64's Avatar
X2 you are probably correct that would help. Like the other poster said, it's supposed to automatic dump the water. Your other alternative would be to set your awning up with the tie down straps and / or the bracket pole set up and set the tilt of the awning more firmly as many others have done
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
cat, catalina, awning
