Old 06-15-2019, 11:01 AM   #1
Chaparral 336TSIK holding tanks?
We have recently purchased our 5th wheel (not our first rig) and I am struggling with holding tank information. The specs say 45 gal black tank capacity and 90 gal gray capacity according to the brochure. Websites list the number of tanks as 1 black and 1 gray. Of course the panel has the generic 2 black sensors and 2 gray sensors, so no help there. And my bay has three dump handles running vertically, the top is a gray water valve, the middle is the black water valve and the bottom one is also a gray water valve. The top valve (gray) won't budge, not even a millimeter. If I tug on it it just pulls the whole panel. So we've spent almost two weeks in it now (average of 3 people) and I have had to dump the gray tank on average about every three days. The black tank not yet dumped and the sensor still only says 1/3 full. We flush the toilet with PLENTY of water so it should be filling up. The gray tank for having a 90 gal capacity, on the other hand, fills really fast. I would say about 4 showers fills it 2/3 to full. And it's not like we take 20 minute showers, 10 minutes tops. I don't do dishes often and other than brushing teeth and washing hands, it is mostly showers. So does anyone know since it is 90 gal, is there actually 2 tanks plumbed together? dumped out of one valve? but each hooked up to a separate sensor set? Or my worse fear would be that the tanks are plumbed opposite and the black water is hooked to the 90 gal tank and the gray to the 45 gal. I have't run the gray past full to see if it starts reading on the second sensor. It wouldn't be the first thing on this rig that was hooked up wrong or labeled backwards. The cable/satellite/antenna connects were a mess. Any information would be appreciated, if you have a 336tsik even better! Maybe I could pick your brain on a couple other issues.
amutsch is offline   Reply With Quote
Old 06-17-2019, 10:29 PM   #2
We also have this 5er. We also had the same problem with the valve at the panel. We ended up using wd40 and pulling on it. After a little while it began to budge. So i suggest just pulling and the apply lubrication and pull some more, it should eventually loosen up.
Typdout is offline   Reply With Quote
Old 06-18-2019, 01:36 PM   #3
Our 360IBL has same specs. But we have 3 separate tanks. Black, shower gray, kitchen gray.
Our kitchen gray fills very slow and it has a sticky valve. While mine is outside the wet bay, I have to spray silicone on the cable and put thetford valve lube down the kitchen sink to keep it moving smooth.
We get about 10 “navy” showers in our shower tank.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition
2018 Chaparral 360IBL w/Andersen Ultimate 2, Tireminder SMART TPMS, Swift Hitch SH04 WiFi Backup/Rear View Camera, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 06-18-2019, 02:57 PM   #4
Fulltime family RVer
First, I'd strongly suggest you reach out to Coachmen/Chapparel directly to get the tank question answered.
My guess is you have 3 tanks like chaps2018 described (1 black, shower gray, kitchen gray). Your kitchen gray pull handle is likely in around the wheels.
But, Coachmen can answer definitely.
ependydad is online now   Reply With Quote
tank
