Old 07-09-2015, 07:13 PM   #1
buskirk21921's Avatar
Chaparral 360IBL
In heavy rain and I notice water pooling on inside window tracks of windows on either side of large back windows. Anyone else have this issue?
Joe and Diane Buskirk
2015 Chevrolet Silverado 3500HD Duramax Diesel 4x4 SWD
2015 360IBL Coachmen 5th Wheel
"Camping is not just a past time it is my relaxing way of life"
buskirk21921 is offline   Reply With Quote
Old 07-09-2015, 07:14 PM   #2
heavynlori's Avatar
Check the weep holes are not plugged
heavynlori is offline   Reply With Quote
Old 07-09-2015, 07:16 PM   #3
Thanks I notice that when I push on lower section of glass it moves a little from silicone bead. Not sure if seal is compromised.
Old 07-13-2015, 10:01 PM   #4
scootingranny's Avatar
We have benchmarked 11 days camping so far in our 360IBL and of those 11 days, we have torrential rain, hail and gusty winds on 7 days. Haven't noticed any water pooling on the back window behind the couch. Is that the back window you were talking about? I will look in the future...
2015 Coachmen Chaparral 360 IBL
2014 Ram 3500 Turbo Diesel 6.7 4wd Crew Cab Dually
scootingranny is offline   Reply With Quote
Old 07-13-2015, 10:02 PM   #5
blwnsmoke's Avatar
I have a 5 day trip coming up in 2 weeks, I'll keep an eye out if it rains as well to see if I get anything collecting in the window frame/channel.
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
blwnsmoke is offline   Reply With Quote
Old 07-13-2015, 10:15 PM   #6
The windows on either side of the couch. These do not have weep holes. I am imagining that the silicone seal has been compromised. Going out to the rally in Goshen early and taking it to the factory to get the spider cracks in front cap fixed and they will look at the windows.
Old 07-14-2015, 05:28 AM   #7
I have heard that some windows have been installed upside down, do not remember which mfg, but check that just in case.
dblr is offline   Reply With Quote
Old 07-14-2015, 08:19 AM   #8
Old 07-14-2015, 08:20 AM   #9
Name:	ImageUploadedByForest River Forums1436880014.238687.jpg
Here is a picture of the issue
Old 07-14-2015, 08:25 AM   #10
IS this window in a slide ? If it is had the same problem. It was leaking from the wall seam and running down inside the wall and running into the window track from above.
Kevin & Judy is offline   Reply With Quote
Old 07-14-2015, 09:57 AM   #11
No this is on the solid wall just before the slide.
Old 07-14-2015, 04:55 PM   #12
Here are the windows.Click image for larger version
Name:	ImageUploadedByForest River Forums1436910862.611512.jpg
Name:	ImageUploadedByForest River Forums1436910886.800807.jpg
On either side of the couch
Old 08-18-2015, 09:03 PM   #13
buskirk21921 did you get this issue fixed? Ever since you posted this thread, we've only had one day of camping when it rained (heavily with small hail). Haven't noticed this yet but was wondering about your issue.
Old 08-18-2015, 09:30 PM   #14
Long story short, no. We arrived at the Coachmen factory on August 7, prior to the FROG Rally in Goshen, IN to drop off the 5th wheel. They were to fix the spider web cracks and address the leaking windows. We picked up the 5th wheel the afternoon of August 7 after they indicated that they worked on the above issues as well as others that I had listed for repair while at the FROG Rally. Around August 10, I noticed that where they had buffed out the cracks there were round patches and the cap was faded at the top. I contacted the warranty/service manager and he came out to the rally and agreed that the cap needed to be repainted. I will have to take it to our dealer for the work. We then had rain and the back right window started to leak again so the warranty/service manager will authorize our dealer to replace the window. I tried to persuaded him to replace all three while at the factory but I guess Lippert(LCI) wouldn't agree. Just be careful if you have a dark cap as these have a good possibility to fade. I noticed that while at the rally that some of the Silverback silver caps and the dark Wildcat caps were fading. I had other repairs done as well at the factory. Wheel for the fireplace would stop and fire would look like it stopped. Island was loose. I did notice at the rally that the underside of the large slide with refrig, stove, entertainment was being shredded, the side closest to the bunk slide. They fixed it at the rally and said it was an actuator bar.
Old 08-18-2015, 11:54 PM   #15
Thanks for the response. Give us some other things to look out for. Haven't had these issues yet but will be on the alert. We do have the first of the 360ibls that have the dark cap so will try to be cautious about that. We have never used the fire place, only turning it on for just a few minutes to show someone how it works and will have DH go under and check out the slide the next time we are out.
Old 08-18-2015, 11:55 PM   #16
Did notice a slight wiggle in the island whenever DH was talking to someone in the kitchen area and he would heavily lean against it. What did they do for that?
Old 08-19-2015, 07:45 AM   #17
blwnsmoke's Avatar
Might just misunderstand your wording but the dark painted front caps are an old cap. FR changed them to the white caps like mine back in August production of last year and all are built with white caps now.
Model production changes happen typically in Aug or Sept of each year even being the same model year.
Old 08-19-2015, 08:05 AM   #18
Ours was probably one of the first 360IBLs made as it does have the dark cap and the interior finish is a bit different than the newer ones with the light cap, like yours. When we bought it in March of this year, the dealership had about 3 with the old cap and interior and about five with the white cap and newer interior. They've sold them all.
Here's a video that shows what ours looks like. The caption says 306 IBL but that's a typo error on part of whoever posted the video:
Old 08-19-2015, 09:15 PM   #19
Ok at this point I regret purchasing the 360IBL. I notice that I have another window leaking(the window at the top of the steps across from the bathroom and the right back side next to couch. All three, the two mentioned and the left back side next to the couch were all resealed at the Rally in Goshen instead of them being replaced. Now I have to add this to the dealer fix. Pictures included. I will post again on mods and things fixed at the Rally.
Old 08-19-2015, 09:27 PM   #20
I think that they put a small wood support under large section but it still wiggles and due to the construction of the island is not ideal as it only has one center post at one side so it is like a tri cycle.
