Old 07-15-2015, 11:32 AM   #1
sledhead77's Avatar
Cheap window blind replacement
First thing, why did they only install the pull down style shades in the slide out room?? With that said, the kids keep beating the snot out of those cheap blinds they put in the bunk area. I am looking to replace them with something like the pull down style that are in the slide room. Just wondering what would be the best option, take measurements and go to the local HD store? Do the shades need to be RV specific? Let me know if anyone has changed out their blinds for something better.
2015 Keystone Cougar 29ROB (wait, can I still be on here??)
TV: 2016 Ram HD 6.4 Hemi 4.10s dual exhaust
sledhead77 is offline   Reply With Quote
Old 07-22-2015, 10:31 PM   #2
Scubanut's Avatar
I have the same issue with mine as well. Not sure how I will retrofit them. Hoping someone has come up with a good solution.
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 07-24-2015, 12:14 PM   #3
sledhead77's Avatar
This is what I did:
https://www.dropbox.com/sc/vvfi3caiy...NyEH_dpfdWfnHa
I used command strips to hook the brackets to the wall Turned out well! I did all of the bunk area windows! Cost $10 including brackets a piece at Lowes.
Old 07-24-2015, 12:34 PM   #4
Blind Replacement
I actually called our dealer to order a couple more blinds that were bent in our camper too and they told me to just take them off and bring them to Menards and have them cut new ones to the same size. They told me it was much cheaper then ordering from the dealer to replace them. I too want to get ride of the blinds because they bend so bad!
happymomx3 is offline   Reply With Quote
Old 07-24-2015, 09:32 PM   #5
Scubanut's Avatar
Sledhead77, are those roller blinds that you used?
Old 07-25-2015, 06:59 AM   #6
cpaulsen's Avatar
Got mine at Lowes. They are Levelor...and can be cut width-wise to size. And very inexpensive. Very similar to day/night shades.
cpaulsen is offline   Reply With Quote
replacement
