06-01-2018, 08:21 AM
#101
bars.)
Originally Posted by jregar
Did you have WiFi out there? What were you using for the connection? Great picture of the area, quadcopter?
I am on Verizon and had a pretty good signal (2-3 bars.) Just used my phone as a hotspot. Someday I will put a small antenna on my roof with a repeater amplifier.
Thanks. I was using a DJI Phantom 3 Pro. Flies like a dream. I was constantly crashing my Phantom 2.
06-01-2018, 09:29 AM
#102
Originally Posted by Homersimpson
Yes, the refrigerator has a small 12 v drain when on propane. Its control circuit is 12 v, but drain is small compared other things you use, like the furnace blower.
If it's a Dometic, it pulls 12VDC for the "brains," but it may very well also have a door heater that pulls about 0.5 amps. Check the wiring diagram on the back of your fridge. On mine, it's item "K", see pic below.
Older models had a switch to turn them off, but the newer models don't.
I've attached a doc that shows you how to disconnect the door heater while maintaining the inside light. If you don't care about losing the inside light, just pull the wire off of pin J2.
2011 Traverse LT, 3.6L, FWD
07-15-2018, 11:44 AM
#103
Got tired of those small useless corner shelves that can barely hold anything without falling. So I took some scrap plastic I had, cut, painted and used 3M exterior double sided tape.
Now it will hold stuff and can leave it there while traveling.
2016 Coachmen Clipper 17bh
2016 Toyota 4Runner
08-04-2018, 09:12 PM
#104
Blackout curtains
Clipper Mods started with ways to cover the front window over the bed, since it doesn't come with a curtain or shade. We do not like to wake at the crack of dawn. DW is retired and I should be, also. We found the morning light to be too bright, so DW sewed removable curtains out of blackout fabric. They are boxed to hang over the valence boxes over each window at night.
Then, there is that front window. Her blackout curtain desigh had to change. We decided to hang a window cover with velcro, but not just any cover: DW started with the blackout fabric, then she began to create an alternate view thru the window. The blackout fabric was sewn over to replicate the black window frame. Scenery was added by sewing original appliques of a trailer, trees, campfire, and even a moose. A lot of work went into it, but it turned out beautifully. See photos.
2017 Coachmen Viking 17FQ
2006 Chevy Colorado Z71
08-04-2018, 09:28 PM
#105
Now that's sharp!
08-07-2018, 02:32 AM
#106
The window covering came out great!
2018 Cedar Creek Hathaway Edition 36CK2
2015 Keystone Bullet Premier 26RBPR
2017 Chevy Silverado LT Z71
01-21-2019, 10:09 AM
#107
For those who have added awning led strip, where did you tie into a power source?
01-21-2019, 11:13 PM
#108
Check out this Enard...
http://www.forestriverforums.com/for...-129351-7.html
It will depend on if you have a power awning or manual...WNY had a power awning and pulled the power off a different place than I did with our manual.
2017 / Ford F-150
2015 / Viking 17FQ
01-24-2019, 05:48 AM
#109
Like BC.campr said, "It will depend on if you have a power awning or manual".
What awning do you have?
01-30-2019, 02:41 PM
#110
Originally Posted by almonteclipper17bh
I have a 17BH and want to want to mount the tv above the window also but have read mixed reviews about mounting it on the exterior wall. How did you go about doing it CDM?
I mounted flat screen on 2018 17fq on end of cabinet over dinette facing the the bed. Then ran coax over to outlet by sink and door. Also painted coax near cabinets so would blend with color. Works great at foot of bed and it rotates for kitchen viewing.
01-30-2019, 09:59 PM
#111
I have a TV above the window in my 17BH and it has been awesome. I attached a wood panel to the studs (which were easy to find because they frame the window!) and attached the TV holder to that. Routed the wires above the door down to the outlets.
I will gladly send a pic if it would help, on the weekend when it isn't minus 29 outside...
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
03-12-2019, 06:25 PM
#112
Great stuff in this thread. I just got my camper (17RD) and haven't done anything to it yet.
Is there anything you did that you wished you hadn't?
2018 Forest River Clipper 17RD
2015 Ram 1500 CC 5.7
03-12-2019, 09:44 PM
#113
Just some little things.
I attached two small plastic drawers under the dinette table to hold flatware and utensils, but I didn’t notice that I installed them close to the table edges, such that the table couldn’t lay flat to make the extra bed. Luckily, I can relocate the drawers and no one will see the extra screw holes on the underside of the table.
And the Robofoot on the trailer jack wasn’t as useful as I had expected. Gimmick.
06-01-2020, 02:23 PM
#114
Originally Posted by CDM
Which stove cover did you use. And how do you mount your tv?
06-01-2020, 03:03 PM
#115
Answers
The stove cover was from Amazon. Here's the description:
Camco RV Stove Top Cover, Universal Fit, Convert Your Stove Top to Extra Counter Space In Your Camper Or RV- Black (43554)
I mounted the TV through the cabinets over the bed. I used a 3/4 piece of ply wood to help anchor it. The mount swivels so you can turn the TV toward the bed or toward the table.
Hope that helps and let me know if you want more pics.
CDM
2015 Chevy Colorado LT
Clipper 17BH
