Has anyone tried this?
Monitor shows 4 lights with tank empty. Wondering if a little clr, to wash and rince fresh water tank, will get corrosion off the sensors in the tank and get the monitor to read correctly again.
Paul n Pam
TV: 2011 F250 SC SB 4x4 6.2
TT: 2011 Coachmen Chaparral 28RBS
Thx folks. There was no odours,was just trying to get the monitor to read properly. Half a tank of water and a good shake down on the highway and we have readings again. Whew,hate to run out of water.
Paul n Pam
Too bad they couldn't come up with a chlorine tab like you use in your pool that you could just drop in the tank every time you fill it so it is a safe amount for the size of the tank.
Think about things before you do them make life easier not harder.
I have seen bleach tablets for laundry use at Walmart.
