05-21-2016, 10:49 AM
Coachmen Catalina build quality
Hello everyone. I am new to this forum. I am considering going from a 2016 FR RPod into a 2017 Coachmen Catalina 243rbs Legacy edition. Can anyone here speak from experience of any major build quality issues that I need to consider? I understand there will probably be small issues as with all trailers. I am mainly conserned with the construction quality. Also does anyone know if the wood frame cage constructed with screws or staples or both? Thanks in advance for your input :-)
05-21-2016, 11:27 AM
No idea. But I would personally spend the extra buck and opt for a aluminum framed trailer such as the Coachmen Apex or the Freedom Express (like I did).
These types have a layer of Azdel In between the walls instead of (wood) luan.
Which is a big plus, eliminates any delamination on your walls incase of a water leak.
That's just my 2 cents.
05-21-2016, 02:16 PM
Stick and Tin trailers are entry level trailers.
So they generally have less standard features than filon/aluminum frame trailers.
05-21-2016, 03:25 PM
I agree. The virtually same trailer can be had in the higher level model. Lighter and better.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
05-21-2016, 03:55 PM
(Dry Huunday)
Im completely satisfied with the build quality of our 2015. Yes its stick and tin held together by glue, staples and screws. We've camped in all kinds of weather conditions from the upper 20s to the upper 90s with an occasional thunderstorm. No leaks and no concerns. I would not hesitate to buy another Coachmen product in the future.
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
05-21-2016, 04:15 PM
(Dry Huunday)
And yes aluminum frame construction is superior to stick frames, but the best built camper in the world will do you no good if you cant afford to use it. Buy what you can afford and enjoy!! Good luck!
Beau & Sue
FurKid Express
05-21-2016, 04:54 PM
Originally Posted by DreiHunde
Im completely satisfied with the build quality of our 2015. Yes its stick and tin held together by glue, staples and screws. We've camped in all kinds of weather conditions from the upper 20s to the upper 90s with an occasional thunderstorm. No leaks and no concerns. I would hesitate to buy another Coachmen product in the future.
Is that a typo..would hesitate? Or did you mean wouldnt hesitate?
05-21-2016, 04:57 PM
(Dry Huunday)
Oh shoot! Yes thats a typo! I did edit the original post! And I would NOT hesitate to buy another Coachmen!!
Thanks!
Beau & Sue
FurKid Express
05-22-2016, 11:58 AM
2011 Coachman Catalena
Our 2011 gets a lot of use and it has had very few if any problems and it is stick and tin. Seams sturdier than the newer aluminum frame but it is heavier.
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
Days camped 2018 136
05-22-2016, 06:55 PM
Our 2015 Coachmen Catalina 263RLS is well built. Our only problem is that 3 water connections were not tightened at the factory (shower and both sides of water pump). After these discoveries, I checked every connection in the unit. All needed some tightening but none of the others leaked. I would definitely buy Coachmen again.
Pops and Nana P.
2015 Coachmen Catalina 263 RLS
50th Anniversary Edition
2004 F-150 Supercrew 5.4L, 3.73 Diff.
05-22-2016, 07:19 PM
I will let you know in a few weeks when my 283RKS comes in!
05-22-2016, 07:23 PM
I'm not sure what you mean. The maintenance on my trailer is the same as any other.
05-22-2016, 07:51 PM
Unless the aluminum frameing is welded, its actually worse than sticks. Most of the RV's built with aluminum frameing join the aluminum pieces with little sheet metal (steel) clips with two cad plated steel sheet metal screws holding them together.Three different metals and just the moisture in the air (humidity) is enough to make a battery that will corrode the sheet metal clip.Then the only thing holding it together are some foam blocks and the inner/outer skin,same as a rotted out stick,but much harder to fix.Aluminum framed horse trailers,and high end bus conversions use aluminum frames,but they are welded.Of course they cost 4 times as much too.
05-22-2016, 08:06 PM
My personal choice is stick and tin. I have looked at several used(some almost new) and seen too much delamination. I have read some on the subject...it appears part of the problems are associated with the sun on the panels. It gets very hot here. I know most people don't have trouble, but I ran out of luck years ago. Just my observation.
2017 Puma 297RLSS
05-22-2016, 08:20 PM
(Dry Huunday)
Aluminium frames arent suspepetal to rot like wood. And I was refering to welded frames. But as I and others mentioned its expensive. The "cant afford to use it" was in reference to spending so much to own it that it sits in the yard because youre broke.
Beau & Sue
FurKid Express
05-22-2016, 08:40 PM
It is IMO better to buy what you can afford and then use it up!
05-22-2016, 08:44 PM
(Dry Huunday)
Thsnks, thats exactly what I was trying to say!
Beau & Sue
FurKid Express
05-22-2016, 10:09 PM
It's been my motto for a long time! When we are done with something there is only enough left for the scrapper!
05-23-2016, 07:54 AM
2016 Catalina
We gave up space in the bath @ bedroom for the extra room offered by the slide out! So far the negatives are no wall switch in the bedroom, the lift rods holding the bed storage open are inadequate. The Windows are all poorly designed to open and close. The screen door latch is poor! The Windows are my priority!!!! 😳
05-23-2016, 08:04 AM
Quality seems tight. Hopefully they used screws. The wood adds weight which concerns
Concerns me! The Aluminum siding also adds weight. For 400 more lbs I could have my ideal floorplan😟
