Old 06-27-2019, 05:56 PM   #1
Coachmen Freedom 248rbs hitch weight
Looking at this trailer web site says the hitch weight is 728lbs
.The Iíve is 5574lbs and gvwr is 7500. Hitch weight seems high is the726 hitch weight fully loaded at 7500 or the upward of 574. I want to tow with f150.
loum35 is offline   Reply With Quote
Old 06-27-2019, 06:42 PM   #2
bikendan's Avatar
Website dry hitch weight numbers are for a stripped down version of the trailer. No battery, no options, no water and no cargo. Propane weight is included in dry number, since around 2009.
Equalizer WDH
Old 06-27-2019, 08:29 PM   #3
REL
Take about 13% the trailers GVWR to be safe even though you may not load to that. That puts you around 975....Check your trucks payload on the door sticker..Add your weight, passenger weight, cargo and the weight of the hitch plus 975.
REL is offline   Reply With Quote
Old 06-27-2019, 08:33 PM   #4
Flybob's Avatar
The 248RBS is heavy. Need a little more info on your F150 as the cargo capacity varies widely depending on how it is equipped.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-28-2019, 02:14 PM   #5
Response Truck information
Truck Info
F150 SuperCab Lariat 5.0 V8 Towing Package
GVWR: 7350lbs
CCC: 1557lbs
People 550
Cargo and Stuff 400
Weight of Hitch 100
Total 1050
Tongue weight 975
Total 2025
CCC 1575
Payload Over 450
Thoughts on my calculations. Thanks
248rbs Specs:
Hitch Weight: 728 lb.
GVWR: 7500 lb.
UVW: 5574 lb.
CCC: 1926 lb.
Old 07-04-2019, 11:50 AM   #6
Hi,
I do have a 2016 248RBS. From what I can tell, it looks quite similar to the newer models.
Here are the numbers:
Tongue : 904 lbs
Axle1: 2778 lbs
Axle2: 2822 lbs
TOTAL: 6504 lbs
Those are the numbers "ready to camp", which for me means:
- 2x 20lbs propane full
- battery
- empty tanks (maybe 1-2 gal of fresh, no more)
- fridge full of food, drinks, beer, etc.
Tow vehicle is a 2018 F-150 SuperCrew 6.5' bed with a 3.5L EcoBoost, max tow package.
EDIT: I'm using a Husky Centerline TS between the 2. Initial setup a a bit longer than chains, but it works wonder afterwards.
Tows just fine and I still have a bit a room for some cargo in the bed if need be.
Hope that helps,
Simon B.
SmnBdrlt is offline   Reply With Quote
Old 07-04-2019, 02:25 PM   #7
Unhappy
Thanks Symon.
Old 07-04-2019, 02:46 PM   #8
I have 2019 248RBS and love the floor plan. Tow it with a 2012 F150 5.0 supercrew 5.5 bed with no issues so far. Although I havenít towed with all full tanks. Of course I have a WDH and use an anti-sway. I added airbags as an extra precaution.
simiHal is offline   Reply With Quote
Old 07-07-2019, 03:21 PM   #9
248 RBS Hitch Weight
We have a 2015 model. We use a 2018 Silverado CC 4x4, with 5.3 and 3.42 gears. Our tongue weight checked on a local scale, loaded and ready to travel was 808. Now that is stuff for only two people and 4 days, and some careful arranging.
Going thru the Quachita Mountains of eastern Oklahoma and western Arkansas,
it wasn't bad, but I was never comfortable. I use a Equalizer WDH.
I really believe any more then 820lbs would test my resolve with my current truck.
Kirt
Hautean1976 is offline   Reply With Quote
Old 07-07-2019, 05:06 PM   #10
Thanks for the replies everyone.
freedom, hitch, weight
