Old 06-11-2012, 10:38 AM   #121
Originally Posted by icon123 View Post
As far as the inverter goes, yes that is normal. The more load that the inverter has to invert 120 VAC to 12 VDC, the harder (hotter) it has to work and therefore the fan kicking in. On one of my coaches, I figured out how many lights I could have on before the fan came on. I don't remember, but I think it was like (4) or something.
Just checked in the 292bhds, 3 lights = fan off, 4 lights = fan on.
icon123 is offline   Reply With Quote
Old 06-11-2012, 11:18 AM   #122
sledhead77's Avatar
Originally Posted by gandr96 View Post
I checked the top of my RV for the radio antenna and the mount is there but no antenna. I'll have to call the dealer again and have it added to the list of parts they are ordering to fix my door.
Thanks everyone for checking!
Has anyone checked into replacing their interior lights with LEDs? I've been told it will make it much cooler on the inside and keep the inverter from working so hard.
I too crawled up there to check out the antenna and skylight. Antenna was laying down but LOOSE! They never put the screw in to hold it to the mount! Not sure how I did not loose it. Wonder if that was the case with yours, it was there but not screwed in place.
2015 Keystone Cougar 29ROB (wait, can I still be on here??)
TV: 2016 Ram HD 6.4 Hemi 4.10s dual exhaust
sledhead77 is offline   Reply With Quote
Old 06-15-2012, 10:11 AM   #123
Ft W crew's Avatar
Has anyone replaced their mattress yet. If so will a regular size queen fit, I know they sold with and RV queen short mattress that has the softness of plywood.
I have a little room between the foot of the mattress and the sliding doors, but was wondering if a regular mattress will fit. Might be a small price to pay and a great upgrade.
2012 Freedom Express Liberty Edition 292BHDS
2011 GMC Yukon XL 2500 4X4 (what a difference)
2007 Ford Expedition EL Eddie Bauer 2WD (sold)
Ft W crew is offline   Reply With Quote
Old 06-18-2012, 12:19 PM   #124
Just picked up my 2013 292 BHDS on friday and had them swap out the new mattress with our full queen from our trade-in. It is very tight and If you plan on using the sliding doors a lot, I wouldn't recommend it. I plan to pull the doors and rig curtains for privacy.
Yellowjacket2525 is offline   Reply With Quote
Old 06-18-2012, 12:35 PM   #125
Ft W crew's Avatar
Yellow Jacket, do the doors still slide just rubbing against mattress or if doors are used a lot they mess up the doors? I would like to use the doors more often than not but in a bunkhouse trailer (3 kids)... well you know...I might just have to get one custom made, I like my sliding doors.....
Old 06-18-2012, 05:10 PM   #126
steeleshark2's Avatar
You can get a custom memory foam mattress made just a little shorter then queen but bigger then what you have now.
steeleshark2 is offline   Reply With Quote
Old 06-19-2012, 06:48 AM   #127
sledhead77's Avatar
I may have to look into this custom mattress thing. So the memory foam mattress is not just a topper but a whole different mattress altogether, correct? I also find that my feet stick off the end of our current mattress as I am 6'3".
Old 06-19-2012, 02:46 PM   #128
The doors will slide with some effort, but I think they will show rub marks after a while.
Old 06-19-2012, 06:25 PM   #129
Rockymountainmattress will make it. Also search on Craigslist for RV mattress in your local area. Some companies advertise there for custom mattresses (not toppers).
Old 06-20-2012, 07:10 AM   #130
gandr96's Avatar
We bought a queen size memory foam topper from Coastco. Even though it is a little bit longer then the RV mattress, it works just fine, and the doors still slide. The nice thing is we can then use it on our guest room queen bed (in our house) in the winter while the RV is in storage.
gandr96 is offline   Reply With Quote
