Old 07-30-2015, 12:12 PM   #241
ehull's Avatar
I have a 2012 Freedom Express 29BHDS w outdoor kitchen. Thought I would share a quick fix if your door brackets fall out since they are held in with small screws in covered particle board. From Home Depot I got some carriage bolts and nylock nuts and a strip if 1 1/2" aluminum. Cut out 4 pieces with a hack saw, smoothed out edges on grinder and drilled holes to match bracket. Painted white and installed. I've had problems with these for awhile and this fix is working great. Pics attached.
Sent from my SPH-L710 using Tapatalk
ID:	84560   Click image for larger version
ehull is offline   Reply With Quote
Old 07-30-2015, 12:32 PM   #242
1atalbot's Avatar
Looks good, no issue to date with ours. I however I do check periodically that they're tight.
1atalbot is offline   Reply With Quote
Old 07-30-2015, 12:36 PM   #243
ehull's Avatar
The one thing that took mine out was not pulling it down from the center of the door. Lesson learned.
Old 07-30-2015, 08:53 PM   #244
Scubanut's Avatar
Ehull I like your mod I have done almost the same without the metal. I will watch my repair closely and If I see any pulling or sigh of weakness I do like your mod.
Scubanut is offline   Reply With Quote
Old 08-31-2015, 10:08 AM   #245
Essential First look at a used 292BHDS
Hi All,
I've read a ton on this post, lots of great advice. I'm going to be driving 3 hours to look at a used 2012 FE 292BHDS Liberty Edition. Current owner has not used it in a couple months, been sitting in NC. I'd like to get a list of things together that all the current owners think I should absolutely DO when I look at the trailer, and then the things I should look for, but don't necessarily need to exercise. I'm coming from a PUP, so I'm new to owning a trailer of this magnitude. Thanks in advance for your advice! We live in FL, so we're hoping this really extends our camping season!
Tdogg0413 is offline   Reply With Quote
Old 08-31-2015, 12:57 PM   #246
Scubanut's Avatar
Check the leaf springs to see if they look like they have been flattened out. Also check the outdoor kitchen door lift Pistons. Lots of issues with the screws pulling out, however an easy fix. I have heard some complaints about water leaks so look for signs of that. Of course check all appliances.
Great trailer!
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Old 08-31-2015, 02:03 PM   #247
ehull's Avatar
Originally Posted by Tdogg0413 View Post
Hi All,
Check tire condition. If they are original set, you might want to get new even if tread still looks good. I have same year/model and 2 tires had the tread separate last month on the same trip.
Always make sure pantry door is closed prior to opening slide out. Mine opened during a very rough trip (bad roads) and the slide out caught the door and ripped it off at hinges, but not before tweaking the bracket on one of the slide out bars. Dealer had to cut off and weld on a new bracket because slide out was binding.
I had a brake assembly fall apart in one of the wheels and destroy the brake drum.
As with my other post...if you have the outside kitchen, always close it from center of door or you risk ripping out the screws that hold the lift piston in place.
Enjoy your RV.
Old 09-01-2015, 07:45 AM   #248
Thanks Ehull and Scubanut, I have both of those things on the list, and the direction to pull from the middle is noted! I will definitely heed the warning on the tires, can either of you tell me what size is on the 2012 292bhds? I've not been able to find it, or what tires have worked best?
Old 09-01-2015, 09:04 AM   #249
1atalbot's Avatar
Our leaf springs went flat in under six months, you can look up in the fender wells and check if the tires have been hitting the floor or bottoming out. Lippert sent us 2,000lbs leafs under warranty and I replaced all 4 in under two hours. Also, they only cost $27.95 per leaf so it's not a deal breaker. All in all we luv the trailer, just normal problems. I also just replaced my rear axle do to the spindle being bent. Again LCI/Lippert covered even though I was year out of warranty. This is why I also put 4 new Maxis tires on the trailer.
Old 09-01-2015, 10:08 AM   #250
Scubanut's Avatar
Coachmen freedom express 292bhds
I have these on my trlClick image for larger version
Name:	ImageUploadedByForest River Forums1441120273.419352.jpg
Factory Trail Express
