Old 09-01-2015, 10:11 AM   #251
Thanks, are those Maxxis as well?
Tdogg0413 is offline   Reply With Quote
Old 09-01-2015, 06:40 PM   #252
Scubanut's Avatar
Power Touring Trail Express is the name on them. Factory junk, but I don't travel to far on them and I watch the inflation.
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 09-04-2015, 09:41 PM   #253
Scubanut's Avatar
Not sure if you pulled the trigger on this but another thing to watch for when bringing in the slide. I left my bathroom door open and the dinette table caught the door and it ripped the table right out of the floor.
Old 09-04-2015, 10:36 PM   #254
ehull's Avatar
Haven't had that happen....yet. Do you pull with the F150? I pulled with a 2007 Chevy 1/2 ton and when I went to Colorado, it didn't handle the mountains too well. Traded in for a 3/4 ton Suburban with 8.1 liter. Pulls great and get excellent yardage (6 - 8 mpg). Considering switching to diesel.
Sent from my SPH-L710 using Tapatalk
ehull is offline   Reply With Quote
Old 09-05-2015, 08:27 AM   #255
Scubanut's Avatar
Yes, I pull with the F 150. 5ltr. I'm pretty much pulling it on the flats. I use a wd hitch with dual sway bars. Not the greatest tow vehicle but I have added a leaf to the springs to firm it up. It actually only drops an inch or two when I connect.
Old 09-05-2015, 06:46 PM   #256
Went ahead and pulled the trigger. Thanks for all the help!
Old 09-05-2015, 07:38 PM   #257
Scubanut's Avatar
Congrats on the trailer! I'm sure you will love it.
Old 09-24-2015, 08:51 AM   #258
sledhead77's Avatar
I now officially hate ours!! Leaks, stuff falling apart, junk! I guess, we wanted to get a fifth wheel anyway, just didn't think it'd be this soon! Hopefully yours works out better than ours did! 3 years and done (if you even count the first year that it was in the shop more then we used it)! Ugh!! Done!! Good Luck!! Oh and I will never buy another Forest River product again!
2015 Keystone Cougar 29ROB (wait, can I still be on here??)
TV: 2016 Ram HD 6.4 Hemi 4.10s dual exhaust
sledhead77 is offline   Reply With Quote
Old 10-07-2015, 10:45 AM   #259
It might just be the photo angle, but it looks like the trailer is a good bit nose up. It will tow much better level or very slightly nose down.
It also looks like there is a lot of space between the front tires and fenders. When you hook up your WDH you should be able to get the front wheel fenders to be the same distance from the ground as when not towing.
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline   Reply With Quote
Old 10-09-2015, 11:49 AM   #260
Thanks, I think it is a bit nose up as well. I'm guessing I will need to drop the hitch ball 1 hole and try it out. My truck rides a little higher than the previous owner's.
As far as the weight distribution, I'm pretty new at this. The previous owner used 3 links, I went to 4. Do I need to move up 1 more? When I lower the height of the ball, will that make a difference how many links I have to use? I'm using an Eaz I Lift that came with the trailer.
