Old 05-16-2015, 06:36 PM   #11
Lefty59, Just drill a additional hole through the part of the window frame that the silver flat bar slides through. Then just drop the "pin" through that hole when the holes on the silver flat bar line up. Only one pin needed. Really much easier than it sounds as I type.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 05-16-2015, 07:14 PM   #12
Thanks everyone! I was afraid the window would just fall off if I opened it. All good now!
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline   Reply With Quote
Old 05-16-2015, 07:24 PM   #13
GLCM Warrior
Lefty59's Avatar
Thanks, Mtelkman! Hadn't thought of doing that. It should do the trick!
Now, once I get that done I only hope I can avoid running into the protruding handle in the dark when the window is only part way open.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 05-17-2015, 08:47 PM   #14
pfeather1's Avatar
Still lost- do you have a picture please?
pfeather1 is offline   Reply With Quote
