Dometic A/C issue
Camping over the weekend and had an issue with our Dometic A/C unit. Temps were in the mid 90's, no clouds. We were parked in full sun... So needless to say, it was hot.
We had the a/c running with the fan on continuous "Hi" for a while to get the inside temp down to where we wanted it. I then switched it over to "auto" so that it would shut off when it reached desired temperature.
The problem: When the desired temp was reached, the fan would shut off (because it's on auto), but the compressor continued to run. It would run for about 3-seconds, then the fan would kick back on. I tried everything on the thermostat, but nothing would fix it. Finally, after the sun went down, it started working properly. It did this on two consecutive days.
Anyone know what would cause this?
Coachmen Apex 288BHS. 13,5k AC.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
