Old 02-26-2015, 07:51 PM   #1
E4 Error message on thermostat
We recently purchased a 2012 Chaparral 270RKS 5th wheel - It has a dometic single zone thermostat - when turned on to any setting I get an E4 error message, but everything seems to work. The manual we have says it's an open circuit or out of range of outdoor temp sensor........can anyone help me with this?
Fleeflicker9 is offline   Reply With Quote
Old 02-26-2015, 08:16 PM   #2
GLCM Warrior
Lefty59's Avatar
You might be able to find the error code and solution here:
http://www.dometic.com/QBank/EPiServ...nual_17590.pdf
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 02-27-2015, 07:19 PM   #3
Hey Thanks Lefty59 for the info - I have the dometic single zone book - my problem is the book does not indicate how to correct the fault. So still need help or ideas on how to resolve the E4 error code. Thanks for your time. Any other ideas?
Old 02-27-2015, 07:22 PM   #4
jtstromsburg's Avatar
What's the temp in the RV and what are you trying to run? AC or furnace? If it's too far out of range, you may have to "help it". ie, in the hot summer after a long tow, a couple times I've had to open windows and get fans moving air first if it's too hot in the camper
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 02-27-2015, 07:43 PM   #5
Flybob's Avatar
Freeze sensor is the sensor evap coils that sense that they are frozen up. Does the error code remain when the RV is warm?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-05-2015, 07:24 PM   #6
Thanks for your input on this error message - jtstromsburg and Flybob
we live in Idaho and the temp warmed up to 58 - went out and checked the thermostat and everything is working fine - so evidently is was the cold temperature. Thanks for the help.........
Old 03-05-2015, 08:57 PM   #7
Glad that's all it is. Happy Campin!
Joel and Teresa
2016 Sabre 34TBOK
thermostat
