Old 03-16-2016, 07:32 PM   #1
2014Catalina 25RKS Deluxe
jeffdawgfan's Avatar
Electrical Schematics
Does anyone have a source to get an electrical schematic for Coachman Catalina Travel Trailers?
jeffdawgfan is offline   Reply With Quote
Old 03-16-2016, 07:40 PM   #2
Flybob's Avatar
It is unlikely you will find what you are looking for. If you do, it will most likely be something generated by an owner. Your best bet is to ask your specific questions here.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-16-2016, 07:45 PM   #3
davel1971's Avatar
you can draw your own schematic by giving a 2 year old some crayons and paper. Would look just like the random loops and piles of wire..
David & Lynn
Old 03-16-2016, 08:37 PM   #4
VinceU's Avatar
Call Coachmen Engineering dept. They, unlike FR, may print you a nice set of 12V DC, 120 VAC and piping schematics. Mine were for a 316K.
Old 03-16-2016, 08:51 PM   #5
Riverss
i got the electrical routing and hook up diagrams from Coachmen for my Catilina MH abt ten years ago i just called them and they mailed me the info requested.
2016 Rockwood 8299 BS
2015 Ram 2500 6.4L CC SB 3.73 posi 2X4
B&W Patriot 16K
Basenji back seat copilot named Lilly
riverss is offline   Reply With Quote
Old 03-16-2016, 09:20 PM   #6
Fulltime family RVer
Originally Posted by VinceU View Post
Call Coachmen Engineering dept. They, unlike FR..
Can you explain/clarify the distinction between Coachmen Engineering and FR?
ependydad is online now   Reply With Quote
Old 03-16-2016, 09:36 PM   #7
davel1971's Avatar
10 years ago, FR didn't own Coachmen. I bet customer service was better then.
David & Lynn
Old 03-16-2016, 10:05 PM   #8
Riverss
10-4 i know that FR did not own Coachmen BUT Coachmen is still Coachmen I think lol just had to add my two cents worth to the conversation. what i was trying to say is nothing ventured nothing gained. good luck!
B&W Patriot 16K
Old 03-16-2016, 10:11 PM   #9
Herk7769's Avatar
Coachmen has been fighting the bit since being acquired by FR. They are a division of FR but have retained a lot of their autonomy. What was before most likely still is.
Coachmen did some maintenance on Coachmen units at the FROG Rally last year, but it seemed somewhat grudging and required some arm twisting for example.
HAM CALLSIGN - KC3FFW
Old 03-17-2016, 09:25 AM   #10
VinceU's Avatar
Sure the divisions are under the same umbrella but some continue to have individual design and construction modules. Not all FR divisions are homogenized, yet.
Old 04-13-2016, 08:29 PM   #11
bbossltd2011's Avatar
Actually I have been corresponding with FR about an electrical issue i'm having with my 2015 coachmen FE 320bhds liberty edition. Gentleman by the name of Steve notified me that there wasn't any electrical schematics for at least my unit. But he somehow knew where the splices were made exactly at under the slides. So I did find a wire that is shorted out in the middle slide, now waiting to see if they have any suggestions on how to perform this task of replacing it. Seems to go from wall fixture to light under cabinet, but it seems to me the wire is running up to ceiling of slide across to far wall of slide and then underneath to light approximately 10' of wire.
Pulled wire but no movement. Any suggestions from this group?
EarnedRest64
bbossltd2011 is offline   Reply With Quote
Old 04-17-2016, 08:42 PM   #12
VinceU's Avatar
If the wire is routed through a exterior laminated wall, slide or fixed, you cannot "renew it". When the wall is fabricated the wire is sealed in insulating foam, alum structure and sandwiched between inner and outer layers, heated and glued. Your best bet is to neatly surface wire between the fittings.
Old 04-18-2016, 08:10 PM   #13
Thanks Vince, I came to a similar conclusion but wanted to avoid wiring out in the open if I could.
EarnedRest64
electric, electrical
