Old 09-16-2018, 01:12 PM   #1
tagalong's Avatar
Exhaust fan and antenna booster
Any other apex owners having interference issues with antenna booster and exhaust fan
When I turn on the exhaust fan the tv loses signal also when you plug in a phone to the charging port at it interferes with the radio signal
tagalong is offline   Reply With Quote
Old 09-16-2018, 04:21 PM   #2
Head Rambler
Sounds like maybe you have one or more bad connections either in the 12VDC power supply and/or the coax at the power supply.
Gotta go campin!
Old 09-16-2018, 06:25 PM   #3
tagalong's Avatar
Thanks for the reply I will start by checking the coax power supply because the 12 VDC power supply at the battery is good not sure where else other than fuse panel to look for the 12 VDC
Old 09-16-2018, 06:27 PM   #4
Head Rambler
Take the wall plate out and check the connections at it.
Gotta go campin!
Old 09-17-2018, 06:48 AM   #5
We have the same problem. When we plug phone into usb port the TV signal is lost. Comes right back in you unplug phone.
2017 Apex 258 RKS
Rich S is offline   Reply With Quote
Old 09-17-2018, 08:11 PM   #6
jtesta1's Avatar
E M F from the fan . Don't know why they Route the cable wires right next to the fan. Not much you can do about it.
jtesta1 is offline   Reply With Quote
antenna, antennae, fan
