Old 07-20-2016, 12:07 PM   #11
MurphyIRE's Avatar
So, I picked up and 12v self priming pump as the back up plan if the AF plan doesn't work. I bought the adapter to go from the 1/2 thread to a std hose. I will test and see if my current pump will fill tank and/or allow system use. I'll keep you posted.
Sean & Susan
Proud Parents of
Two US Marines
2016 Chapparal Lite 29MKS
2010 F-250 6.4L Diesel
MurphyIRE is offline   Reply With Quote
Old 10-30-2016, 11:47 AM   #12
MurphyIRE's Avatar
Finally, here is the CB for my water system.
Name:	water CB turned.jpg
Sean & Susan
Proud Parents of
Two US Marines
Old 10-31-2016, 06:27 AM   #13
wingedone's Avatar
I got something like this years ago (drill pump).
https://www.amazon.com/ECO-FLO-Produ...rds=drill+pump
You hook it up just like any water pumped from a well, set your system to fill, and run.
Be sure to run some diluted bleach through it first.
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
wingedone is offline   Reply With Quote
Old 10-31-2016, 07:39 AM   #14
MurphyIRE's Avatar
I had forgotten about those! Thanks for the info, I'll order one
Sean & Susan
Proud Parents of
Two US Marines
Old 10-31-2016, 08:02 AM   #15
KyDan's Avatar
That will work for sure but just some thoughts.... The drill powered pumps I've seen aren't very fast. Be prepared with a spare drill battery or 2. Hopefully you can lock the drill trigger on and lay it down while you sip your
cold brewskie and watch the water level in your carry jug.
I suggest you test it at home by maybe just pumping a 5 gallon bucket and time it. That will also let you know about drill battery life as well as drill motor heat.
The shower hose into the gravity fill port is a winner if your outside shower
is on the same side as your tank fill. Mine is on the far opposite side
Peace!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-44
camping, tank
