Old 04-22-2016, 06:17 PM   #11
Todouble's Avatar
I've got a 2014 f250 towing 12k. Run at 7 on my gain. There is a way to go thru and change the ibc settings from low to high or low med high. Done thru in dash menu setups. Forgot exactly how.
Todouble is offline   Reply With Quote
Old 04-22-2016, 09:54 PM   #12
2007 WildCat 32QBBS
05CrewDually's Avatar
IBC set @ 7 with 21,000 LBS combined tandem axle 5er. The only time I had to turn it up to 9 was because of a failed grease seal on one of the wheels. If the brakes are adjusted and not contaminated with grease then 7 is plenty.
05CrewDually is offline   Reply With Quote
Old 04-23-2016, 07:58 AM   #13
blwnsmoke's Avatar
I have mine set at 7.5 at about 13k. Haven't had any concerns with braking.
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
blwnsmoke is offline   Reply With Quote
Old 04-23-2016, 09:16 AM   #14
Ford TV owners - whats your brake gain? (stock controller)
F150, probably 8500-9000 6.5 or 7.0 usually. I do a stop test when leaving my property so It will be the same test every time I leave and weight variances change my gain.
2016 Rockwood Sig. Ultra Lite 8312SS Platinum
2016 GMC Sierra 3500
Equal-i-zer 10K WDH
Tadi Brothers 9" Wireless 120 degree Rear Cam
2015 Nights Camped: 4
2016 Nights Camped: 8
hazmat91180 is offline   Reply With Quote
Old 04-23-2016, 12:21 PM   #15
Stormrider151's Avatar
7.0 on dry pavement and I back it up to 6.0 when it's wet.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 04-23-2016, 01:05 PM   #16
CaptnJohn's Avatar
2016 F250 with 6.7 towing 11,500 5er. Medium effort set at 7.5
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 04-23-2016, 01:50 PM   #17
sfsgm's Avatar
Wfd Controller Gain
2012 F-350 with 31 foot, 14k lb trailer. Gain set to 6.5-7.0.
2016 Nike Take Down Wrestling Shoes
38 ft square Dollamaur High School Wrestling Mat
sfsgm is offline   Reply With Quote
Old 04-23-2016, 02:05 PM   #18
KMANUEL74's Avatar
I had a 2010 Ford SCREW towing 5.5k. Used 7.5 gain with that. My new 2015 F150 SCrew I set it to 9 and still did not have the stopping power I had with the 2010. Might be something wrong with the IBC, it decided to lock up the trailer brakes constantly. Had to pull fuse in truck to drive the remainder 750 miles home
KMANUEL74 is offline   Reply With Quote
Old 04-23-2016, 02:31 PM   #19
Chevy
2014 1/2 ton pulling an evo trailer dry weight is 4500 max trailer cap is 9700. I set my brakes at 7
Stetay is offline   Reply With Quote
Old 04-23-2016, 03:36 PM   #20
wow am I the outlyer. 2011 Powerstroke on my 11k 5r I run 4-5. Never higher.
palmetto rogue is offline   Reply With Quote
controller, ford, brakes
