Old 04-23-2016, 11:51 PM   #31
Keep mine at 6.5. Pulling 9500lbs through the mountains of BC so pretty much always up and down 7-10% grade. Use tow haul in the transmission a lot and definitely saves on the brakes. 6.2 Gasser .
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2013 22 nights.2014 57 nights.2015 116 nights
2016. 96 nights 2017 72 nights.
Filterman is offline   Reply With Quote
Old 04-24-2016, 11:42 AM   #32
CaptnJohn's Avatar
I believe your truck only has 1 setting for effort. My 2016 F250 has the range 1 - 10 in low, medium, and high effort range. You may well be at max. Check the trailer tow section of your manual to see if you have more than 1 range. All are set at low effort at the factory when shipped.
Also, those of us with a diesel rely heavily on the engine brake.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 04-24-2016, 11:50 AM   #33
Witch Doctor's Avatar
I checked my 2007 ford after I have been reading this thread, there is no adjustment except 1 through 10, may be why I'm at 8.5 with a 9400 trailer loaded. Also have the tow haul but it helps but not like the newer models
But with 39,000 miles I'm keeping it for awhile
Sent from my SM-N920V using Tapatalk
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 04-24-2016, 12:31 PM   #34
Stormrider151's Avatar
Originally Posted by ronandpat View Post
I have a 2014 f350. I set my gain to 9-10. The 2015 and newer trucks have the ability to adjust to low, medium or high setting through the dash menus with a 1 to 10 level for each setting but not trucks in prior years. Bummer, because I feel like I want a little more trailer brake.
X2. I don't know if it's even possible, but I would almost consider disabling the factory controller and install the P3. I had it on my previous truck and it worked much better.
Stormrider151 is offline   Reply With Quote
Old 04-24-2016, 01:00 PM   #35
V-Lite Fun's Avatar
Mine was set at 10 when I bought the truck new. I've never fiddled with it. I don't use much brake in tow/haul mode. Maybe I should lower the setting. The brakes never lock up set at 10 though.
Forest River Flagstaff V-Lite 26 WRB. 2015 Ford F 250 diesel, Hensley Arrow Hitch
http://rvadventuresofpetedoll.blogspot.com
V-Lite Fun is offline   Reply With Quote
Old 04-24-2016, 02:48 PM   #36
No I have an effort range as well. Keep it at medium.
Floyd & Carolyn
Old 04-25-2016, 05:00 PM   #37
What year and make is your TV
Old 04-25-2016, 05:02 PM   #38
My last post was for filter man, this phone didn't quote him or it just user error
Old 04-25-2016, 07:39 PM   #39
2012 F150 with Max Tow package 6.2, 6spd,7700GVW. 4X4.
Floyd & Carolyn
Old 04-25-2016, 08:22 PM   #40
farmncamp's Avatar
Good information everyone. My 5th wheel is heavier than my TV which is why I like to keep the brake setting a bit higher (9). In my 2012 F350 stock controller there are no high or low settings. This is something they added to the newer models. I'm satisfied with the braking power in the flat prairies where I live.
I intend to install electric over hydraulic disk brakes in my 360IBL in the coming weeks. I'll post pictures and info about that project in a new thread.
2015 Coachman Chaparral 360IBL
2012 6.7L Ford F350 SRW
53 nights camped in 2017.
farmncamp is offline   Reply With Quote
controller, ford, brakes
