02-23-2018, 08:57 AM
Freedom 246rks battery dead
I had just read somewhere that people disconnect their battery when not using the trailer. Well yesterday I went out and my battery was dead. it's only been unplugged for 10 days. So is taking the battery box apart and disconnecting each time the best way to handle this or can I just throw the main breaker. Nothing was left on that I could tell just stray voltage?
02-23-2018, 09:30 AM
Throwing the main breaker won’t help since breakers are for the 120vAC side. Dead batteries are on the 12vDC side. Are you sure you don’t have a battery disconnect switch?
02-23-2018, 09:44 AM
There are parasitic current draws ( CO/Propane detector, TV, DVD player) that will kill the battery is a week or two. You have five options.
1. Disconnect negative cable from battery when storing
2. Adding a battery disconnect switch that will do the same thing only easier.
3. Add a battery tender ( not a trickle charger) to compensate for the current drain.
4. Leave the unit plugged into shore power.
5. Remove the battery and take it home.
Option 3 and 4 are only available if you have power available ( even 15A outlet) where you store the RV.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-23-2018, 09:47 AM
If you wanted to use a breaker this would work. https://www.amazon.com/dp/B00DIGK346...a-351181099581
As noted above, I would suggest a disconnect switch. BEP 701 Battery Switches - On-Off https://www.amazon.com/dp/B005DUUL9W..._JKcKAbP3E4J9T
Either way it is better to disconnect the battery as there are parasitic drains on it.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
02-23-2018, 09:52 AM
I added the BEP switch listed above to my negative cable. It kills everything.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
02-23-2018, 10:18 AM
Thanks all I'll be installing a disconnect i think
02-23-2018, 10:21 AM
I don't know if one but I'll check again thanks
02-23-2018, 01:12 PM
It's another example of a bad PDI from the dealer.
This should have been covered during the walkthrough.
Nearly ALL RVs have parasitic power drains.
As FlyBob listed, one of those things need to be done, otherwise the battery will be dead in a few days.
02-23-2018, 02:26 PM
ARLO
Those small draws should not be enough to kill a good battery in a week or 10 days they only draw milliamps worth of power. No different from the car on the car Dealers lot with the radio and the pcm etc..You may just have a weak battery.Chronic problem, have the battery checked to make sure it is good. I believe you can buy solar powered trickle chargers that you can connect to them also.
02-23-2018, 02:46 PM
I also have the 246rks and the same thing happened to me. I also installed a battery disconnect switch and haven't had any problems since. I don't know why they don't simply add this to all units... sheesh.....
02-23-2018, 06:06 PM
Arithmetic
Let's do some arithmetic. A typical battery is 50 Amp-hours. A 200 milliamps draw per hour would draw 5 amp-hours in a day or completely draw the battery for in ten days.
02-23-2018, 06:13 PM
Per Mfg spec. The CO/Propane detector alone is 130ma.
TST Tire Monitors
2 100W solar panels
02-27-2018, 11:23 PM
I have the 246RKS and yes, I had to install a battery cutoff switch as well. No issues since then.
2015 F150 XLT Sport 4WD 3.5L EB
2014 Freedom Express 246RKS
03-07-2018, 08:54 AM
Hi Guys
I also have 2015 246rks and yes battery goes dead. What I found out there was a .250ma draw (1/4 amp). Using a Fluke meter checking for a draw. Found out the radio is the problem. Fuse is located bottom right of the fuse panel. I pulled mine. The radio doesn't sound good to me anyway. If you should go boondocking the radio will pull battery down quickly. 1/4 amp is a big draw.
goodday
lou
03-07-2018, 03:05 PM
Originally Posted by sweet lou
Hi Guys
goodday
lou
Hey a member for 2 years and 1st post!! You must have been doing some serious lurking....
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
03-09-2018, 05:45 PM
Would a solar maintainer charger work?
03-09-2018, 06:21 PM
Easiest fix is adding a battery disconnect switch.
03-09-2018, 06:23 PM
