Old 12-26-2016, 06:23 PM   #1
TMAC69's Avatar
Freedom Express, 2011, Slide out issue
So, first time to post an issue, hopefully someone can offer some insight. My single slide out does not want to, uh, slide out. It's electric and the motor seems to run fine, the issue is that it seems to be hung up on one side. I'm new to the RV community, we bought it used but in very good shape... this is not the first time I've deployed the slide, just the first time it's gotten "hung up".
TMAC69 is offline   Reply With Quote
Old 12-26-2016, 06:30 PM   #2
Flybob's Avatar
Not sure about the 2011, but on mine, there is an axle the width of the slide with a gear on each end that engages a toothed track on each side of the slide. This insures that both sides of the slide move in sync. Check the gear on the side that appears to not move. It could be jammed or loose on axle.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-26-2016, 06:34 PM   #3
TMAC69's Avatar
Nice, any tips on how to access thru the "board" material protecting the undercarriage without tearing it or ripping it ?
Old 12-26-2016, 07:28 PM   #4
Left Coast
Would need to remove screws that hold it up...Not a big deal to cut a three sided door and use black Gorilla tape to reseal the cuts.......just make sure the hinge is the forward facing side......a lot of dealers do it this way....
Old 12-27-2016, 12:36 PM   #5
Tmac - If you have a conventional electric slide (not the Swintech dual motor electric drive), there is a square tube cross piece that extends between the two gear drives for the slide. This keeps them in sync so each side of the slide travels at the same speed. At each end of this tube, it connects to the gear assembly with a shear bolt. It's likely one of these bolts has sheared off. You can get replacement bolts at Lowes (get the same size/grade bolt). If this is the problem, you need to determine why the bolt sheared. Maybe something is jamming the movement of the slide.
You shouldn't need to cut into anything to see this mechanism. Just look under the slide, adjacent to the frame beam.
Ken
2018 Rockwood 2706WS
2007 Ford F-350
rvee-nut is offline   Reply With Quote
Old 12-27-2016, 04:15 PM   #6
Slide jamed
Mine did that, found a cabinet door stuck on one side. Worth a look
pdqparalegal1 is offline   Reply With Quote
Old 12-27-2016, 05:04 PM   #7
TMAC69's Avatar
Ken, will definitely check to see if anything is blocking and the bolts. Thanks everyone. I will let you guys know what I find out!
Old 12-27-2016, 05:11 PM   #8
crunchman12001's Avatar
Is the unit level, mine would hang up if way out of level.
EDIT.. From your post on 10/26/16
"Hello everyone, we recently purchased our 2011 Freedom Express and I just noticed that the slide appears to be off set, is this a track issue that i can fix or is this a "take-it-in-to-the-shop" issue?"
Did you ever fix this issue? Sounds like it is still hanging up, if you did not get the slide squared up, you probably sheared a a shear pin.
2015 F-250 FX4
Old 12-27-2016, 08:58 PM   #9
Me too. Check the interior closely.
2016 Coachmen Freedom Express Liberty Edition 292BHDS
FRRVR is offline   Reply With Quote
Old 12-27-2016, 08:59 PM   #10
Left Coast
Adjust the latch....
Old 01-06-2017, 09:10 PM   #11
TMAC69's Avatar
So... thanks everyone for the useful tips. Unfortunately, water damage has rotted the wood. No worries, getting her fixed and will take proper care of her.
Old 01-06-2017, 09:39 PM   #12
You are welcome, thank you for the follow up.
2015 F-250 FX4
2011, freedom express, slide, slide out
