Old 01-30-2015, 10:42 AM   #1
Freedom Express 246RKS
New 2015 Freedom Express 246RKS is being prepped. I'll pick it up on Tuesday. As soon as the weather improves, I hope to get it out on a shakedown cruise.
Formerly owned a Rockwood 2604, so weight and length are similar. Looking forward to getting out and about again.
Regards,
SKOM
2015 Coachmen Freedom Express 246RKS
2014 Ram 1500
SKOM is offline   Reply With Quote
Old 01-30-2015, 01:56 PM   #2
Congrats!!!
Old 01-30-2015, 02:10 PM   #3
Flybob's Avatar
Check stab jacks. Mine are mounted on a thin steel plate that is not directly under the center of the frame. Slight flex leads to some instability. FR will be correcting when I pull out for spring. If you still have any negotiating power left, try to get them to add a winterizing bypass on the water pump as part of the deal. Unless you live in warm climate, you might need it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-02-2015, 05:32 PM   #4
Thanks. I saw your post and picture of stabilizing jacks elsewhere. I'll check into it tomorrow when I pick it up.
SKOM
2014 Ram 1500
freedom express
