Old 04-05-2016, 09:08 PM   #1
Freedom Express 292BHD Level
I had a question about leveling my trailer. Stickers and the manual say level and set stabilizers before slide out. I follow that but find that after the slide out is out it is not level anymore?
Are there any suggestions or anything I am missing?
2016 Coachmen Freedom Express Liberty Edition 292BHDS
FRRVR is offline   Reply With Quote
Old 04-05-2016, 09:34 PM   #2
CaptnJohn's Avatar
No, you are on the right track ~~ the reason to level 1st is to keep the slides on track.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 04-06-2016, 03:24 AM   #3
Try leveling your trailer, then add 1 or 2" of shim blocks under the slide out side of the trailer, then slide out.....you should be good!
bjcohn is offline   Reply With Quote
Old 04-06-2016, 08:45 AM   #4
Coachmanjk's Avatar
I added a bubble level to the front of my trailer. I also level just so the trailer is leaning slightly to the left. Then when the slide goes out it levels the trailer. Then I drop the stabilizer jacks.
JK
Hanover, PA
2015 Coachmen FE 282BHDS
Coachmanjk is offline   Reply With Quote
Old 04-06-2016, 12:56 PM   #5
Carknocker Family
Ida Ratherbe Camping's Avatar
X2
I usually leave the slide out side an inch high. Then when slides come out. Pretty darn near level.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 04-06-2016, 02:50 PM   #6
Cutty
bbcutright's Avatar
I level up then I always add about 4 to 6 inches under the tires on the slide out side before pulling slides out. This lets the springs sag and I'm almost always level. It works for me but others tell me that's not right.
bbcutright is offline   Reply With Quote
Old 05-07-2016, 11:21 PM   #7
jbhodj's Avatar
Ok if your supposed to level before you deploy your slide outs and you have one side higher (the slide out side) to make level when your slides are out then your not really level side to side then are you? In other words your un level by an inch or more on one side to make level when you put the slide outs out. Defeats the purpose of being level before your slide outs get deployed I think right? What am I missing here?
jbhodj is offline   Reply With Quote
Old 05-09-2016, 03:44 AM   #8
Prime Member
Level your trailer, lower the stabilizers and open your slides. If your trailer needs additional leveling afterwards, raise your stabilizers just enough so you can add additional leveling blocks then lower them again.
Sent from my iPad using Tapatalk
Temporarily Camper-Less
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 05-09-2016, 04:15 AM   #9
crunchman12001's Avatar
Originally Posted by Ida Ratherbe Camping View Post
X2
X3
2015 F-250 FX4
Old 05-10-2016, 09:21 AM   #10
Thanks for the suggestions. I will follow that next weekend. That's what I was thinking but wanted to see if I was on the right track or not.
Old 05-10-2016, 01:48 PM   #11
jbhodj's Avatar
Getting my 292BHDS this Wednesday and will defin be doing this as suggested above to hopefully come out level when slides go out
Old 05-10-2016, 02:00 PM   #12
Level for us means the slide side is one inch high.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-10-2016, 03:49 PM   #13
I go RV'ing not Camping
jgourlie's Avatar
We have to also have the slide side 1 inch high in order to get level, or a half bubble on the level
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 05-11-2016, 08:28 AM   #14
sledhead77's Avatar
We always used a 1" thick slab of wood to make the slide side higher. Always leveled er out. Now I got auto levers
2015 Keystone Cougar 29ROB (wait, can I still be on here??)
TV: 2016 Ram HD 6.4 Hemi 4.10s dual exhaust
sledhead77 is offline   Reply With Quote
freedom express
