Old 04-14-2019, 06:25 PM   #1
Freedom Express Question re; Power to Microwave
Hi Folks... I have a 2017 FE 246rks and when we opened it up this spring everything was fine except for the Microwave. There is no power to it. Everything else has power and I cant seem to find the fuse that goes to the Microwave. All the fuses are marked and none say Microwave. It is a Furion Microwave... Any thoughts? Thank you.
stevegotl is offline   Reply With Quote
Old 04-14-2019, 06:30 PM   #2
Flybob's Avatar
The microwave is 120VAC and is protected by a breaker. Fuses are used to protect the 12VDC portion of your system. Check the breakers by turning them off than back on. The microwave is also plugged into an outlet. You may have to remove a panel or drawer to access the outlet.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-14-2019, 06:34 PM   #3
cavie's Avatar
The Microwave is not on a fuse, It is on a 120 volt circuit breaker. Fuses are for 12 volts. The micro wave may be on the GFI circuit which starts in the bathroom. Reset the bathroom GFI outlet and see if the micro wave comes on. If not check the 15/20 amp circuit breakers. Turn them off then back on. Don't just look at them.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-14-2019, 07:10 PM   #4
bikendan's Avatar
As others have said, microwave is 120v AC and like your home microwave, is on a breaker.
After you resolve this, suggest that you Google "the 12 Volt Side of Life", so you learn how the two different electrical systems work in your RV.
Equalizer WDH
Old 04-14-2019, 07:36 PM   #5
there have been a few posts recently about microwaves not working. the issue is there is a switch or automatic relay installed that switches power between the microwave and some other device, typically a fireplace. i don't know your model and i don't know if this is applicable or not but it might be something to look at.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 04-14-2019, 07:38 PM   #6
wmtire's Avatar
Just to make sure, you are plugged into some form of 120 volt AC power?
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 04-14-2019, 07:53 PM   #7
ive seen post about fireplaces and microwaves being on the same circuit with a switch turning one off and the other on. use the fireplace last fall?
Kimber45 is offline   Reply With Quote
Old 04-14-2019, 10:04 PM   #8
Retired Old Fart
dward51's Avatar
FE 246RKS does not have a fireplace, so that is not the issue. Here is a photo of my 2015 FE 256RKS fuse/breaker panel with the factory markings. Microwave is the next to the bottom breaker (bottom half of a double 15amp breaker).
Since you have the same trailer, just a 2017 model, I would presume yours is the same. I would flip the breaker to off and then back on, even if it looks like it's not tripped. I've seen other breakers trip but no move the lever fully to the mid position like you would expect.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 04-15-2019, 05:02 PM   #9
Check and reset all GFCI breakers as well. My Microwave outlet was tied to GFCI in the bathroom rather than the one in kitchen area.
Dennis Burke
2003 Coachman Cross Country Elite 376DS
2002 Jeep Wrangler
2014 Ford Edge
burkede is offline   Reply With Quote
freedom, freedom express, microwave, power
