Old 11-02-2014, 12:21 PM   #1
fresh water tank
Just purchased a Coachman Freedom Express 322 RLDS and have several more questions as some of them have already been answered on here and I thank you for that. I am learning more on here than I did at the walk thru. My trailer has a city water hook up and a place to fill the fresh water tank as I guess most do. My question is when on city water does the fresh water tank fill. If so I would want to drain it before leaving the park to get rid of the extra weight. Thanks again as I can see this will be a long learning curve but you folks are helping. twosocks
twosocks is offline   Reply With Quote
Old 11-02-2014, 12:26 PM   #2
Witch Doctor's Avatar
Your city water hook up should not fill your FW tank, if it does you have a problem. Do not run your pump when hook-ed to city water it's pressurized already just like at home.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-02-2014, 12:36 PM   #3
Thank you
Old 11-02-2014, 08:46 PM   #4
KDHfan's Avatar
If you haven't already, I'd suggest a water pressure regulator on your city water hose... Just a few bucks at Walmart or Amazon.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
fresh water, tank, water, water tank
