Old 04-28-2013, 09:08 PM   #11
Whatdidigetmyselfinto's Avatar
Figured out the no water pressure. My father in law came over when we got home today, we hunted down the water pump (dealer must have forgot to tell us where it is) its hiding behind carbon monoxide detector right next to the breaker/fuse box. (2012 29dds) what a strange place to put it. Near electrical, and no were near the fresh water tank. The hose used to pump in anti freeze was open, hence the sucking of air. Guess we'll still be heading to dealer to figure out the leak.
Thanks again for all the help!
Whatdidigetmyselfinto is offline   Reply With Quote
Old 05-01-2013, 08:53 AM   #12
daydreaming about camping
jeeplj8's Avatar
tracing those things on new trailers is always interesting. best to be patient and have a good square drive bit to pull the screws they use for access panels.
Agree with everyone else about a loose clamp topside of your tank. Once you figured out the pump side of the problem, did it pump water well, and did this cause your leak to re-emerge?
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 05-02-2013, 08:37 AM   #13
Water runs great, now. Leak has slowed to almost nothing and the tank still shows full. Just have to remember not to over fill it again.
Old 05-09-2013, 11:39 AM   #14
pkurek's Avatar
My 2013 when sanitizing this spring for first trip in it, I had the same thing. Had a small drip from underbelly. Pulled a couple screws and pulled down underbelly slightly, had to cut is a bit. Found fill tube clamp loose. A long 1/4 dr extention and 5/16 socket worked. resealed and good.
Paul, Dawn, Brennan & Blake Kurek
2013 Coachman 292BHDS
2005 F150 Lariat SuperCrew 4x4
1 spoiled lab and 1 even more spoiled boxer
pkurek is offline   Reply With Quote
