Old 04-26-2013, 07:44 AM   #1
Whatdidigetmyselfinto's Avatar
Fresh water tank leaking
We were planning on heading out this weekend for the first time in our brand new 29dds trailer, filled up the fresh water tank last night and now this morning there's a big wet spot underneath. It's looks like its coming from where the drain valve exits the underside of the trailer. The valve itself isn't leaking. UGH!
Whatdidigetmyselfinto is offline   Reply With Quote
Old 04-26-2013, 07:51 AM   #2
Might be the vent hose is loose or disconnected.
Old 04-26-2013, 07:59 AM   #3
Dave_Monica's Avatar
Are you sure that it's not just the tank overflow? All FW tanks are vented but some also have an overflow line.
Dave
Old 04-26-2013, 08:12 AM   #4
So I just went back outside to look at it closer, I can hear it dripping inside the underbelly directly underneath the fill spot. Of course it's all sealed up and I can't see anything without unbolting the plastic covering. That's not gonna be fun.......
Btw the gauge still says full, so its a small leak, hopefully just an over flow valve.
Old 04-26-2013, 08:17 AM   #5
Doesn't sound like it's the overflow line as it would be piped to drain onto the ground.
Looks like you may have to take a section of coroplast down to find out for sure.
Dave
Old 04-26-2013, 08:44 AM   #6
Engineer of Crazy Train
ChooChooMan74's Avatar
If it was my guess, loose clamp or the fill tube cracked at the clamp.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 04-26-2013, 11:15 AM   #7
I have pulled out about a half dozen screws and pulled down what plastic covering I could, the rest of it is glued up to the waste tank piping. Of course I can't see very much but I do see that's its still a slow drip. I called the dealer to see if they had any advice. He said same thing, loose clamp on fill hose, or similar hose. They are two hours away and of course booked solid till mid to end of next week. Hopefully as the water level goes down in the tank the leak will stop, gauge still shows full. Wish me luck!
thanks for the advice!
Ralph
Old 04-26-2013, 11:20 AM   #8
Herk7769's Avatar
Drain out a little water and see if it stops.
HAM CALLSIGN - KC3FFW
Old 04-26-2013, 11:34 AM   #9
Great minds think alike. Just drained off about a half a gallon and no more drip.
Old 04-27-2013, 02:10 PM   #10
Got into our spot last night, got everything setup, dinner made and eaten. No water pressure. Pump runs tank is full. So this morning I did a search and got some very useful info. As best I can tell, the fill hose is so loose that the pump is sucking air. Ugh! Looks our trip next week will be to the dealer.
Oh I forgot to mention its been a lite steady rain all day here in central Iliinois. Could be worse I guess.
Ralph
