Old 05-30-2016, 04:19 PM   #1
rocketman1083's Avatar
Fridge not working on 120
Got to finally take the new rig out to enjoy the weekend. Everything worked well I ironed out a few bugs but for some reason my fridge will no longer work off of 120. It worked fine at the house as we were packing up to leave and worked for a short while even after we arrived but it will only work on propane. I checked the fuses on the board and they all check ok, I confirmed power at the outlet behind the fridge and got 115v and I even went as far as checking the resistance through the heating element (44 ohms) and I had power at the jumpers on the main board. Could there be something simple that I missed?
Thanks a million
Bob
2015 Dodge RAM 1500 Laramie w/ 4 Corner Air Suspension, 3.92 gears, 32 gal fuel tank, integrated brake controller
2016 Coachman Freedom Express Liberty Edition 320 BHDS
rocketman1083 is offline   Reply With Quote
Old 05-30-2016, 04:26 PM   #2
Insert witty title here
Is it set to auto?
Sent from my iPad using Tapatalk
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 05-30-2016, 04:57 PM   #3
Yeah it's set to auto and the auto light is on. If I unplug it, it will switch to propane automatically and when I plug it back in the board senses the AC power and kills the propane burner but I never hear it kick back on.
Old 05-30-2016, 05:08 PM   #4
Ford Idaho's Avatar
Does the "check" light come on?
Old 05-30-2016, 05:11 PM   #5
northstar1960's Avatar
and you are getting voltage to the heating element ? but it's not getting hot or you're not getting voltage to the element ?
northstar1960 is offline   Reply With Quote
Old 05-30-2016, 06:29 PM   #6
The check light is off but the auto light is on. I'm getting 120v at the board jumpers where the element plugs into it and as far as I can tell, the element isn't getting hot anymore.
Old 05-31-2016, 07:18 PM   #7
Well I'm not sure what changed but I turned off the propane up front and the AC start working again to cool the refer. Weird!
Old 05-31-2016, 07:26 PM   #8
was the fridge all ready cold ? could be it wasn't calling for cooling
Old 05-31-2016, 07:46 PM   #9
That may be a possibility. But last night I left it on AC for almost 2 hours and kicked on but it may have just not been calling for heat. I may let it run on AC over night and switch back to propane tomorrow to test it again that is switches correctly to propane and back to AC.
Old 05-31-2016, 07:50 PM   #10
But on second thought it must have been calling for cooling because the propane would light immediately if i unplugged the fridge from the outlet
fridge
