Old 09-17-2018, 12:39 PM   #1
Jmsx2's Avatar
Front Landing Gear Holes Not Lining Up!
Hey Gang. I took our 2018 Chaparral 336tsik in for some warrant work. We only used her once. One of the repairs was the pin on the front landing gear being bent. A month later a pick it up and had a heck of a time releasing the pin. Got her home and had to fight to get the pin back in breaking the spring.
Hereís my problem. The holes inner/outer donít appear to be lined up. Is there an adjustment that I can do? Or is she going back to the dealer which is a 90 minute drive. Suggestions are welcome and thank you.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
2018 Coachmen Chaparral 338 TSIK
2016 (Seasonal Site) Chariot Park Model
2015 Chevrolet Silverado 2500HD
Jmsx2 is offline   Reply With Quote
Old 09-17-2018, 12:45 PM   #2
Denver To Yuma In 90 Days
If you have to take it back up to them, make sure they will do it while you wait!
And maybe get a free lunch out of them...
JohnD10 is offline   Reply With Quote
Old 09-17-2018, 12:48 PM   #3
jtatum65's Avatar
I have the big brother Shasta to your Chaparral. On the landing gear the locking pins are held in place by 2 bolts and nuts. Just loosen then and realign them with the holes in the outer leg tube.
Jim & Evelyn Tatum
2018 Shasta Phoenix 336RL FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2019 = 26
Nights Camped 2018 = 28
Nights Camped 2017 = 27
jtatum65 is offline   Reply With Quote
Old 09-17-2018, 12:58 PM   #4
Jmsx2's Avatar
I attempted that. Even went as far as putting the pin only in after the assembly came apart. I can actually look through and see the inner and outer holes not lining up. I had to use a rubber mallet to get it through. Not sure if thereís an adjustment or if the landing gear needs repaired or replaced. Thank You.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 09-17-2018, 01:23 PM   #5
jtatum65's Avatar
Well its new so take it back and get it replaced under warranty.
Jim & Evelyn Tatum
Old 09-17-2018, 01:32 PM   #6
Jmsx2's Avatar
Yep. I think thatís what Iíll need to do.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 09-17-2018, 02:10 PM   #7
Yep, if adjusting the two bolts doesn't line things up your only other recourse would be to enlarge the holes slightly with a drill bit. On a brand new unit, I'd be taking it back.
Be sure to test it BEFORE you leave the lot. Since it was ALREADY there to have that issue looked at, who knows the outcome the 2nd time.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 09-17-2018, 02:28 PM   #8
Jmsx2's Avatar
I donít think enlarging the holes is the direction I want to go. You are absolutely correct, it needs to go back.
Thank you
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 09-18-2018, 06:09 PM   #9
This is just a wild guess( mine are hydraulic), but try taking the lower part out and turning it 180 degrees. The holes may not be perfectly centered and if they had it apart to fix it once, may have been put in backward. Just a guess but may save you a trip back,
mgas is offline   Reply With Quote
Old 09-18-2018, 06:36 PM   #10
Jmsx2's Avatar
I like your wild guess!! One would think that shouldnít matter, but I think itís worth a shot. I wonít get to it until Sunday. Iíll let you know. Thanks.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
