Old 08-15-2019, 05:42 AM   #1
Hate the shower curtain rail, options?
My new Apex Ultra Lite 289TBSS has an aluminum rail that is like a mini I beam that the shower curtain rides on. While taking a shower your constantly running against that curtain in the narrow shower. Is there an aftermarket bowed rail that would create the illusion of a larger shower stall? I'm guessing that I could remove this rail, fill the screw holes with some white or clear RTV and mount up a new outwardly curved rail and gain much needed inches of elbow room. I'm not even a large human at 5'8" and 185#, I can't imagine how tight this feels to some of the monster sized humans we all see!Click image for larger version
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
Old 08-15-2019, 05:55 AM   #2
jd50i's Avatar
If capable, get a straight track and form as you want or.......
Maybe something like these?
https://www.amazon.com/MorningRising...SIN=B01E03OSWI
https://www.amazon.com/VRSS-Flexible...SIN=B06XDZSV26
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 08-15-2019, 07:39 AM   #3
A extend a shower might work for your situation.
Stromberg Carlson EXT-3542 Extend-A-Shower-White https://www.amazon.com/dp/B0031XXW4O..._yhvvDbZY7M238
It extends out while you shower. It retracts in when you're not. I was very happy with it in my TT. This way, it wont permentntly hang over your sink.
Skip12 is offline   Reply With Quote
Old 08-15-2019, 08:16 AM   #4
llr
I put a curved bar In a prior TT, helped a lot
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
llr is offline   Reply With Quote
Old 08-15-2019, 09:12 AM   #5
How does it transition from the inward position to the outward? Like, what do you do to move it?
Old 08-15-2019, 09:19 AM   #6
Mopar Guy
my grey wolf 24js has the same style I beam but it is curved, so that might be an option also.
Dave
2019 Grey Wolf 24JS- sold
1998 Holiday Rambler Imperial 41wds
Cost4133 is offline   Reply With Quote
Old 08-15-2019, 04:34 PM   #7
I just did this. I unscrewed the center I-beam curtain rod support and pulled the I-beam out about 6 inches along the ceiling, Then I screwed the I-beam support bracket in the new location. It flexes nicely and the end brackets hold on to it. Made a world of difference using the shower and didn't cost anything.
rbarm is offline   Reply With Quote
Old 08-15-2019, 05:31 PM   #8
I find if you shower side way, your shoulders dont brush the curtain as much. I don't shower in it often but when we do, we stand sideways. Curved rod would be a good idea!
Gerogesin is offline   Reply With Quote
Old 08-15-2019, 06:20 PM   #9
Check here, around 4:00 min
2011 Traverse LT, 3.6L, FWD
Old 08-16-2019, 06:50 PM   #10
Here are pictures of my mod.
ID:	212604   Click image for larger version
ID:	212605   Click image for larger version
Old 08-17-2019, 06:43 AM   #11
Tell us about your mod, where did you source that bowed aluminum rail?
What steps did you take?
What is the approximate total cost to reproduce this mod?
Where did you source any hardware?
Old 08-17-2019, 07:00 AM   #12
Larry,
I have a Rockwood minilite. The shower curtain rail came with the TT. It is a small I-beam aluminum rail that holds the sliding hooks that the shower curtain hangs on. It is held to the ceiling by 3 brackets. I just loosened and removed the center bracket and pulled it out in the center creating the arc. The aluminum is soft enough to bend without creasing it, and I pulled it out carefully to make a reasonable bow. Then screwed the bracket to the ceiling in the new position. The two end brackets hold tight. $0 cost. I’m not sure if all shower curtain brackets are the same.
Old 08-17-2019, 07:06 AM   #13
keegantimber's Avatar
Lol. Totally dependant on specs like a WDH and proper set up
Are you overweight on the front?
Whats your tongue length?
Maybe your overweight on the rear?
How bout that rear bumper?
And whats your inflation pressures?
And in my situation whats your overall height? For that low bridge..err..shower curtain
Lol
keegantimber is offline   Reply With Quote
Old 08-17-2019, 05:02 PM   #14
Originally Posted by rbarmhome View Post
Larry,
That's the money shot right there as far as quick and cheap enhancements go for the shower. This morning I did as you described and then too a shower in the camper. It's not perfect, but I didn't have a cold wet shower curtain stuck to my arms, back and butt the entire time. Flexing it out about 2 or 3 inches made a noticable change in working space.Click image for larger version
ID:	212680Click image for larger version
ID:	212681Click image for larger version
Old 08-19-2019, 01:35 PM   #15
rlh1957's Avatar
You can get tri-slide glass doors and put them up. The tri gives a wider opening than standard two slide doors. They can be custom made to fit your opening. I ordered them for about $300, so it's not a cheap fix, but really dresses it up and keeps the water where you want it. Worth it on a new trailer, not sure a used buyer would see the benefit unless they'd dealt with shower curtains and rails before. Sorry I don't remember where, but it would probably be HD or Lowes special order.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 08-19-2019, 04:04 PM   #16
$300 is.... Negligible! That is 1% of the unit cost. I just spent $1000 on 2 Fan-Tastic fans and 2 of the vent cover things in black. What's $300 between friends!
Old 08-19-2019, 06:23 PM   #17
My shower curtain track came bowed outward. Not enough. The Extend-A-Shower works great. It's even better when not showering. No longer rubbing my right shoulder on the curtain when sitting on the toilet when the rod is pushed into the shower. About $30 on Amazon.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
show, shower
