Old 08-15-2019, 05:42 AM   #1
Hate the shower curtain rail, options?
My new Apex Ultra Lite 289TBSS has an aluminum rail that is like a mini I beam that the shower curtain rides on. While taking a shower your constantly running against that curtain in the narrow shower. Is there an aftermarket bowed rail that would create the illusion of a larger shower stall? I'm guessing that I could remove this rail, fill the screw holes with some white or clear RTV and mount up a new outwardly curved rail and gain much needed inches of elbow room. I'm not even a large human at 5'8" and 185#, I can't imagine how tight this feels to some of the monster sized humans we all see!Click image for larger version
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,100 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,680 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is online now   Reply With Quote
Old 08-15-2019, 05:55 AM   #2
jd50i's Avatar
If capable, get a straight track and form as you want or.......
Maybe something like these?
https://www.amazon.com/MorningRising...SIN=B01E03OSWI
https://www.amazon.com/VRSS-Flexible...SIN=B06XDZSV26
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 08-15-2019, 07:39 AM   #3
A extend a shower might work for your situation.
Stromberg Carlson EXT-3542 Extend-A-Shower-White https://www.amazon.com/dp/B0031XXW4O..._yhvvDbZY7M238
It extends out while you shower. It retracts in when you're not. I was very happy with it in my TT. This way, it wont permentntly hang over your sink.
Skip12 is offline   Reply With Quote
Old 08-15-2019, 08:16 AM   #4
llr
I put a curved bar In a prior TT, helped a lot
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 08-15-2019, 09:12 AM   #5
How does it transition from the inward position to the outward? Like, what do you do to move it?
Old 08-15-2019, 09:19 AM   #6
Mopar Guy
my grey wolf 24js has the same style I beam but it is curved, so that might be an option also.
Dave
2019 Grey Wolf 24JS
1990 D350 dually reg cab. 5x14 injectors, s362 SXE turbo. Lenny Fustini Built 727. 4200spring stage 5 pin
Cost4133 is offline   Reply With Quote
Old 08-15-2019, 04:34 PM   #7
I just did this. I unscrewed the center I-beam curtain rod support and pulled the I-beam out about 6 inches along the ceiling, Then I screwed the I-beam support bracket in the new location. It flexes nicely and the end brackets hold on to it. Made a world of difference using the shower and didn't cost anything.
rbarmhome is offline   Reply With Quote
Old 08-15-2019, 05:31 PM   #8
I find if you shower side way, your shoulders dont brush the curtain as much. I don't shower in it often but when we do, we stand sideways. Curved rod would be a good idea!
Gerogesin is offline   Reply With Quote
Old 08-15-2019, 06:20 PM   #9
Check here, around 4:00 min
2011 Traverse LT, 3.6L, FWD
Old 08-16-2019, 06:50 PM   #10
Here are pictures of my mod.
ID:	212604   Click image for larger version
ID:	212605   Click image for larger version
show, shower
