Old 07-06-2014, 06:09 PM   #11
Ford Idaho's Avatar
I run 65 mph yesterday into a strong crossing head wind (think 11 o-clock)
Tires aired to 65 psi dropped my mileage to 8.9 but no other problems.
As the other have suggested slow down, if you are still uncomfortable park it.
Old 07-06-2014, 06:21 PM   #12
asquared's Avatar
Glad to hear you made it home safe. If you don't already have it, I would suggest switching to a wdh that has integrated sway control like equal-i-zer or Reese dual cam.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-06-2014, 06:30 PM   #13
SKnight's Avatar
Originally Posted by Weezer View Post
(screw spec. If the tire can take it, give it.)
IMO this could be dangerous advice.
Originally Posted by OldCoot View Post
I believe you stated: "airing the tires to their max (screw spec. If the tire can take it, give it.) is about all you can do on the road."
Which leads one to what could be a possible very dangerous situation. Not good. IMHO
Y'all can read, right?
Airing the tires to THEIR max. Seems plain to me, how else might I have expressed that so y'all would understand me?
Old 07-06-2014, 06:45 PM   #14
Herk7769's Avatar
Not even sure if I know why hard tires will mitigate sway
Seems counter intuitive. Park it till the winds die down and take an extra day, IMO.
ID:	57349   Click image for larger version
Name:	Ford Eco-Boost flipped long camper.jpg
ID:	57350   Click image for larger version
ID:	57353   Click image for larger version
ID:	57354   Click image for larger version
Name:	Ford Ecco boost Towing LONG Camper.png
HAM CALLSIGN - KC3FFW
Old 07-06-2014, 07:56 PM   #15
SKnight's Avatar
I have a hard time believing you actually said that. Lends a bit of credence to a recent conversation though.
Old 07-06-2014, 08:29 PM   #16
JonClark's Avatar
Like I said I have an appointment with the dealer on Tues for some other issues and gonna have them go over everything again and make sure I'm hooked right, level and all. 35 mph gusts suck but should not have been that bad. Gonna bring the tt loaded like I'm going camping. Thanks again everyone for the helpful tips
kids think tt stands for tan turd.
JonClark is offline   Reply With Quote
Old 07-06-2014, 08:43 PM   #17
Herk7769's Avatar
As you say...
Perhaps you can explain it to me. Exactly how does hard tires mitigate trailer sway? Links to source material would help me understand it.
Inquiring minds and all that.
Well, here is an interesting article on trailer sway that says that too much or too little tire air pressure for the load can CAUSE sway.
Search Results
  1. Tips on How To Tow a Trailer | etrailer.com
    www.etrailer.com/faq-trailertowtips.aspx
    If repositioning the load and equipment did not help reduce the sway, a sway control .... Tires with too much or too little air pressure can cause the trailer to sway."
    http://www.etrailer.com/faq-trailertowtips.aspx
    That makes an lot more sense to me.
This assumes that the correct type is actually ON the trailer. Only ST or LT tires should be on the trailer. P type tires will cause excessive sway and tire failures due to over loading (rated tire load must be reduced by 9%).
Old 07-06-2014, 08:51 PM   #18
As you say...
Especially the link to substantiate disregarding the max pressure and "airing the tires to their max (screw spec. If the tire can take it, give it.)"
Old 07-06-2014, 09:24 PM   #19
B and B's Avatar
This simple, leave air pressure where it is suppose to be. SLOW DOWN, it takes you an extra half hour to go somewhere so be it, safety first! I have run into the same problem with the TT, slowing down 10 kmph make the trailer stop swaying.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-06-2014, 09:42 PM   #20
Herk7769's Avatar
I found many references to slowing down.
If the trailer still sways, it is either mis-loaded (tongue to actual trailer weight ratio outside safe limits 10%-15%), no WD hitch and trailer weighs more than 50% above tow vehicle (i.e. truck weighs 5,000 and trailer more than 7,500 pounds and no WD hitch), or too long for tow vehicle wheel base (saw lots of those references too).
