07-06-2014, 02:30 PM
Help...
Trying to get home in massive crosswinds, any ideas. I'm swaying all over the road
kids think tt stands for tan turd.
07-06-2014, 02:36 PM
Other than parking until evening, tightening up the sway control more than normal and airing the tires to their max (screw spec. If the tire can take it, give it.) is about all you can do on the road.
Good luck and be safe!
07-06-2014, 02:45 PM
Tires have 70 lbs so will tighten sway and drive slow. Thanks
07-06-2014, 03:42 PM
We went thru the same thing on our way home this afternoon. Just slowing down helped immensely. Even just going from 65 mph down to 60 mph made a huge difference!!
Good luck and safe travels!
07-06-2014, 04:11 PM
Thanks down to 50 now
07-06-2014, 05:05 PM
DO NOT GO above max pressure stated on the side of the tire. Just slow down, even if it's down to 40-45mph. You have no idea "What the tire will take" OR the wheel before a minor bump/road crack could cause a blowout.
07-06-2014, 05:37 PM
What the tire can take is printed on the side of the tire. Why I said air the tires to their max.
Spec is printed on the door sticker. Max pressure the tire can take is expressed in psi and kpa.
07-06-2014, 05:42 PM
NELA
IMO this could be dangerous advice.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
07-06-2014, 05:46 PM
Originally Posted by SKnight
What the tire can take is printed on the side of the tire. Why I said air the tires to their max...
I believe you stated: "airing the tires to their max ( screw spec. If the tire can take it, give it.) is about all you can do on the road."
Which leads one to what could be a possible very dangerous situation. Not good. IMHO
07-06-2014, 05:52 PM
Didn't air up the tires. I checked the air pressure and they were all at factory spec. Was a little white knuckles when I said 70lb they are at 65 psi. I've been involved in blowouts so not testing air pressure when I don't know what they can take. Tightened sway bar and just made it home now. Thanks for the advise. It's going in for service tues and gonna have them inspect everything and put another sway on it. New to this but should not have had this hard of a time.thanks again everyone
07-06-2014, 06:09 PM
I run 65 mph yesterday into a strong crossing head wind (think 11 o-clock)
Tires aired to 65 psi dropped my mileage to 8.9 but no other problems.
As the other have suggested slow down, if you are still uncomfortable park it.
07-06-2014, 06:21 PM
Glad to hear you made it home safe. If you don't already have it, I would suggest switching to a wdh that has integrated sway control like equal-i-zer or Reese dual cam.
2014 Sabre 34REQS-6
07-06-2014, 06:30 PM
I believe you stated: "airing the tires to their max (screw spec. If the tire can take it, give it.) is about all you can do on the road."
Y'all can read, right?
Airing the tires to THEIR max. Seems plain to me, how else might I have expressed that so y'all would understand me?
07-06-2014, 06:45 PM
Not even sure if I know why hard tires will mitigate sway
Seems counter intuitive. Park it till the winds die down and take an extra day, IMO.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
07-06-2014, 07:56 PM
I have a hard time believing you actually said that. Lends a bit of credence to a recent conversation though.
07-06-2014, 08:29 PM
Like I said I have an appointment with the dealer on Tues for some other issues and gonna have them go over everything again and make sure I'm hooked right, level and all. 35 mph gusts suck but should not have been that bad. Gonna bring the tt loaded like I'm going camping. Thanks again everyone for the helpful tips
07-06-2014, 08:43 PM
As you say...
Perhaps you can explain it to me. Exactly how does hard tires mitigate trailer sway? Links to source material would help me understand it.
Inquiring minds and all that.
Well, here is an interesting article on trailer sway that says that too much or too little tire air pressure for the load can CAUSE sway.
Search Results
- Tips on How To Tow a Trailer | etrailer.com
www.etrailer.com/faq-trailertowtips.aspx
If repositioning the load and equipment did not help reduce the sway, a sway control .... Tires with too much or too little air pressure can cause the trailer to sway."
http://www.etrailer.com/faq-trailertowtips.aspx
That makes an lot more sense to me.
This assumes that the correct type is actually ON the trailer. Only ST or LT tires should be on the trailer. P type tires will cause excessive sway and tire failures due to over loading (rated tire load must be reduced by 9%).
07-06-2014, 08:51 PM
As you say...
Especially the link to substantiate disregarding the max pressure and "airing the tires to their max (screw spec. If the tire can take it, give it.)"
07-06-2014, 09:24 PM
This simple, leave air pressure where it is suppose to be. SLOW DOWN, it takes you an extra half hour to go somewhere so be it, safety first! I have run into the same problem with the TT, slowing down 10 kmph make the trailer stop swaying.
B and B
07-06-2014, 09:42 PM
I found many references to slowing down.
If the trailer still sways, it is either mis-loaded (tongue to actual trailer weight ratio outside safe limits 10%-15%), no WD hitch and trailer weighs more than 50% above tow vehicle (i.e. truck weighs 5,000 and trailer more than 7,500 pounds and no WD hitch), or too long for tow vehicle wheel base (saw lots of those references too).
