Old 05-14-2015, 10:50 PM   #1
Exclamation Help! fresh water drain plug missing ...
Just went to fill up with fresh water as we are leaving in the morning for the long weekend, and it seems the dealer left off the drain plug when they PDI'd the new trailer as its all pouring out the drain.
Unfortunately the dealer is 2 1/2 hours away, so my question is what kind of plug/cap do I need for this? Size of the fitting? Something I can pick up from Canadian Tire or Rona/Home Depot?
2015/05/04 - 2016 Coachmen Freedom Express 310BHDS Maple Leaf Edition
YEGrolo is offline   Reply With Quote
Old 05-14-2015, 11:07 PM   #2
Would this work? Says its drain plug for water heater, is it the same?
http://www.amazon.com/Camco-11630-Wa.../dp/B00C5T7PSO
They have it with a wrench at Canadian Tire:
RV Water Heater Drain Plug Kit | Canadian Tire
Old 05-14-2015, 11:08 PM   #3
iceblaze580's Avatar
Most likely its a 1/2 female thread cap or half inch threaded male plug
iceblaze580 is offline   Reply With Quote
Old 05-14-2015, 11:12 PM   #4
If you thread something like this on it, you will be happier in the long run.
Homewerks Worldwide 1/2 in. PVC Sch. 40 FPT x FPT Ball Valve-VBVP40B3B - The Home Depot
madmaxmutt is offline   Reply With Quote
Old 05-14-2015, 11:38 PM   #5
Problem now is I need something ASAP in the morning so we can get going as everything is closed now for the night, so whatever I can find the fastest I'm just going to put on for now.
The one with the valve would definitely nice as there's no plug to lose.
So the Camco water heater plugs I found above should work for now I assume? They are listed as 1/2".
Thanks!
Old 05-15-2015, 12:48 AM   #6
GLCM Warrior
Lefty59's Avatar
If I'm not mistaken, water heater plugs are male thread & the fresh water tank cap will be a female thread. At least that's how they are on mine.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 05-15-2015, 07:13 AM   #7
Mr. Dan's Avatar
So, following Lefty59's lead, I'll ask if you can see the threads on the outside or are they inside the end-of-drain connector?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 05-15-2015, 07:21 AM   #8
bubbles's Avatar
Typically those plastic/nylon/metal plugs/caps can be found at HD, Lowes and most any hardware store.
Old 05-15-2015, 01:22 PM   #9
ChipBruce's Avatar
When I dewinterized mine the first time, the dealer had placed the drain plug in the water heater compartment. May be a long shot, but worth checking before heading to Home Depot. Good luck and hope all goes well.
Chip Bruce, RPh
Kansas City, MO
ChipBruce is offline   Reply With Quote
Old 05-15-2015, 09:21 PM   #10
The plugs I linked above on Amazon/CT were a perfect fit. Afterwards we found it in the kitchen sink! Guess I have extras now.
Old 05-15-2015, 09:29 PM   #11
Mr. Dan's Avatar
I'm glad you solved the problem and the mystery.
Thanks for reporting back.
Old 05-15-2015, 09:30 PM   #12
Flybob's Avatar
Should be able to pick at any hardware store. Most are 1/2 PVC male threaded plugs.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
water, drain, fresh water
