Old 06-02-2019, 03:01 PM   #1
Help me identify this please
I am trying to determine what water drain line this is. We never use our fresh water holding tank and went to use a couple weeks back and filled it up only to have it all drain out of the the (attached pic) drain. is this the low drain valve? or is it the fresh water drain? and obviously something is missing
Many thanks for your help. this is located at the rear driver side of the trailer.
https://www.dropbox.com/sh/yjm37wo8l...AnKky8rOa?dl=0
ID:	206200   Click image for larger version
Happy Campers
baybeebare is offline   Reply With Quote
Old 06-02-2019, 03:10 PM   #2
I would say if it's close to your Fresh water fill up it may be your fresh water tank drain.
2019 Coachmen APEX 265RBSS
2002 Ford F250 Super Duty Lariat 4x4
zmanecu68 is offline   Reply With Quote
Old 06-02-2019, 03:34 PM   #3
shouldn't be a low point drain, there would be two of those one hot and one cold. Prob the fresh tank drain (if you never use it) a simple plastic plug from any hardware or big box store plumbing section should plug that.
unless it starts to drip when the tank is full then its the fresh tank overflow
Kimber45 is offline   Reply With Quote
Old 06-02-2019, 03:35 PM   #4
Flybob's Avatar
Looks like the FW tank drain. It should have a plug in the end. Many people forego the plug and add a 1/4 turn valve to allow for easier draining. Most likely a 1/2" non tapered thread.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-03-2019, 03:22 AM   #5
X2
It looks like your fresh water drain without a plug in the end. Get a plug from a local dealer and you'll be OK.
SniperDroid is offline   Reply With Quote
Old 06-03-2019, 06:01 PM   #6
1/2" drain from Amazon:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
1/2" PVC Close Nipple 1/2" from Amazon (also available in irrigation supplies at Home Depot):
https://www.amazon.com/dp/B008O1DSDI...&ref=aa_rscomp
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 06-03-2019, 06:28 PM   #7
derek6669's Avatar
Check and see if there is a valve beside your water tank. I have a drain like this and the valve is under the bed beside the water tank
derek6669 is offline   Reply With Quote
Old 06-03-2019, 11:45 PM   #8
Retired Old Fart
dward51's Avatar
Looks like the FW drain on my trailer. Should be a cap on that line though.
Another tip that it's FW drain would be is it located near or between those 2 u-channel's under the trailer that hold the FW tank up? If it is, you confirmed it's the drain. Mine is straight out of the tank with no valve, just a cap that I take off to drain.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 06-04-2019, 07:41 AM   #9
Could be the overflow for fresh water tank. Mine is on right side about 3feet from rear about 6 inches in.
Chuck.virginia is offline   Reply With Quote
Old 06-05-2019, 09:17 AM   #10
glsimms's Avatar
Me thinks baybeebare went bye bye.....
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is online now   Reply With Quote
