Old 11-01-2014, 11:41 AM   #1
hot water bypass
I'm new to travel trailers I know where the hot water bypass is but can't remember if the knobs are in line if that is open for the tank or closed. When I de winterize do I flush the lines first then open the hot water tank bypass or open the bypass and then flush or does it even matter? The trailer was winterized by dealer. Freedom Express Liberty Edition 322 RLD 2015. Thanks
twosocks is offline   Reply With Quote
Old 11-01-2014, 11:58 AM   #2
Witch Doctor's Avatar
In line is open, closed is in the T position. You clean the antifreeze out and add some bleach to the FW tank an sterilize with a little bleach in the system then change the by-pass valves back. When you can't smell bleach at each faucet. Running your pump. might take two times or so. They should not have put antifreeze in your FW tank. I have a valve between my pump and FW tank that I close before winterizing then open it to flush the system.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-01-2014, 04:24 PM   #3
Old 11-01-2014, 06:47 PM   #4
thanks for the info gentlemen and the drawing was a big help
Old 11-01-2014, 08:05 PM   #5
Lon
Lon's Avatar
This was very helpful to me as well. I'm wondering if it would be helpful to have a general category called "Newby's Corner" for new owners like me and twosocks who have basic questions like this one.
Lon is offline   Reply With Quote
Old 11-01-2014, 08:27 PM   #6
Lon I LOVE that idea! Lately I've been keeping everyone busy with my newbie questions. It's nice to see I'm not the only one.
kellieh04 is offline   Reply With Quote
Old 11-09-2014, 10:41 AM   #7
PJRNM's Avatar
A picture.....if it helps. This depicts winter valve position. Summer would be the opposite.
PJRNM
2012 Dodge Ram 1500 4X4
2013 Apex 258RKS
PJRNM is offline   Reply With Quote
Old 11-09-2014, 10:45 AM   #8
PJRNM's Avatar
I also found it helpful to make a list, I found myself forgetting to run pink stuff through the outside shower... Now I refer to the list and don't forget a minor detail and have to go back to finish.
Turn Valves to bypass water heater.
1) Kitchen Sink
2) Bathroom Sink
3) Inside Shower
4) Outside Shower
5) Toilet
6) Low Point Drains
PJRNM
2013 Apex 258RKS
Old 11-09-2014, 11:28 AM   #9
1) Kitchen Sink
2) Bathroom Sink
3) Inside Shower
4) Outside Shower
5) Toilet
6) Low Point Drains
That is a good list except it is impossible to fill your BTF system which has a plastic valve Vacuum/ backflow preventer. I hope being in the wall it won't crack.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-09-2014, 11:33 AM   #10
A lot of the answers that you could be looking for you might find in the library. But people don't mind helping someone, so just ask away. I always learn something from answers then save them to my book marks. By the way if I haven't said it already.....WELCOME
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-09-2014, 11:51 AM   #11
PJRNM's Avatar
What's BTF? I did the same procedure last year with no issues. Always trying to learn.
PJRNM
2013 Apex 258RKS
bypass, hot water, water
