Old 04-23-2015, 11:55 AM   #1
Hot Water Heater
On first day out had good hot water while on shore power. Next morning water was cold had to switch to propane. First time out with new Catalina.
tejedabob is offline   Reply With Quote
Old 04-23-2015, 11:59 AM   #2
Try pushing the 2 rubber buttons on the left upper side. It might have tripped the 110v hi limit switch. I think the one on the far left is propane and the other 110v.
Old 04-23-2015, 12:02 PM   #3
Tried to reset, didn't work.
Old 04-23-2015, 12:07 PM   #4
If the breaker isn't tripped inside the trailer, your element may have bitten the dust. If it has, make sure you buy the wrench to remove the old one and install the new one. I think they are around $10 or less.
Old 04-23-2015, 12:11 PM   #5
wmtire's Avatar
Not really knowing what steps you have taken, here is a FAQ that explains the operation of the common Suburban water heater. You may have the switches in the correct positions already.
Just to be sure, if you used it on electric by turning on the switch on the face of the water heater, you didn't turn it back off by chance and forget about it?
Just pure dee spitballing here.
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
heater, hot water, water, water heater
