Old 06-13-2018, 08:24 PM   #1
How important is a stove hood?
We've been considering getting a Apex Nano 193BHS and just noticed that it does not come with a stove hood and vent unlike some of it's competitors like the mini winnie 2100 BH or the Roo 19.
How important is a stove hood? Just open the window and you're fine or can condensation be an issue?
PNWCamper7 is offline   Reply With Quote
Old 06-13-2018, 09:00 PM   #2
For me a stove hood is pretty important. If one does any more than just boil water on the stove top there's a lot of vaporized oils, some from the meat and what you use to cook with, that float upward. Might not seem like much but take a look at the filter in the hood over most any stove that's been in use for a while and you'll see how much "greasy" residue builds up. If this isn't sucked in by the hood and directed outside then it eventually deposits itself on ceiling, walls, wood work, etc. A hood may not prevent all of this but it will cut it down considerably.
That's just me take on how important a hood is.
I love the fact I have an outside kitchen for this reason. Anything that gets fried or saute'd gets done outside.
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
Old 06-13-2018, 09:13 PM   #3
Kaadk's Avatar
It's a must for me. If I don't use it, the toaster sets off the smoke alarm, which in turn sets off the dogs and kids.
Old 06-13-2018, 09:16 PM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I agree 100% with Mike. The trailer is a fairly small enclosed space and without a range hood you will have grease and crud running down the walls and on the ceiling in no time.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-13-2018, 09:21 PM   #5
cavie's Avatar
Very important. I have one but the stupid thing blows back in your face. Cutting a hole in the side and venting a new one this summer. Removes cooking smells that won't end up in the master bed. Humidity. helps to cool. I could go on and on.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 06-13-2018, 09:32 PM   #6
Canadian Member
If you do most of your cooking outside you could easily live without it. If you fry anything on the stovetop, or generate anything other than steam while cooking, it's necessary. Incidentally, our electric toaster doesn't cause any problems without the stove hood on.
2019 Rockwood Signature 8290BS
Old 06-14-2018, 01:51 AM   #7
Follow up question then: how hard is it to install a range hood? Looks like Amazon sells 12v Hengs range covers and matching exterior vent covers, but the prospect of cutting into the exterior wall seems scary. On aluminum construction how do you even know where the studs are?
Old 06-14-2018, 02:04 AM   #8
If you install a hood, you don't want to hit a stud, you want to go in between the studs. I would investigate first before buying one without to determine stud location. Best bet is to get one with a hood if the stud location is bad.
Old 06-14-2018, 04:12 AM   #9
It's needed. I already set off the smoke alarm and nothing was burning. Just some Canadian bacon in the pan.
2016 Silverado LTZ 1500
2018 Freedom Express 192RBS
AlaskaErik is offline   Reply With Quote
Old 06-14-2018, 05:07 AM   #10
nomad297's Avatar
A range hood that vents to the outside of the camper is a great thing. A range hood like I have, that doesn’t have an exhaust duct to the outside and only has a “filter” to capture any smoke and smells, is useless. This is just about the only complaint I have with my Windjammer. What were they thinking when they decided to go this route?
Bruce
