Old 09-03-2014, 03:18 PM   #11
dcheatwood's Avatar
In thinking low point hot and cold drains and fresh water drain.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 09-09-2014, 11:07 PM   #12
Send a message via Skype™ to chuckw5kav
Soooooooooooooo have we found out, do we have Pictures I'm losing sleep over this
2017 Durango Gold G384RLT
Coachmen Owners Association
2005 Ford F350 Dually
W5KAV
Last years Camping 125 days
chuckw5kav is offline   Reply With Quote
Old 09-09-2014, 11:19 PM   #13
GLCM Warrior
Lefty59's Avatar
When my gauges seem to be giving incorrect indications, I've had good luck in getting them back on track by disconnecting the battery (pull the battery disconnect on the Wildcat) and then pushing the button for the tank with the 'faulty' gauge indication. The lights usually flash momentarily and then when the battery is reconnected, the reading is correct. My last trip out my fresh water tank gauge was reading full even when my water pump was sucking air from an empty tank. Used this method and it fixed my issue.
Not sure why it works...just know that it does...at least for me.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 09-10-2014, 01:01 PM   #14
Anacortesians
Can you not actually see the tank to check the level? When we first got our Georgetown, there was no documentation showing where th FW tank was located. I finally tracked it down by listening to it fill.
It turned out that there are two cupboards down at floor level where the queen-size bed snugs up when the slide is retracted. For some daft reason, both were fastened closed by screws through the doors into the frame. I'd assumed they were dummy doors to look like the upper wardrobes. I took the screws out and opened the doors and there was the FW tank. There's actually a drain line going out to somewhere near the back bumper with a hand valve. Opening the valve drains the tank.
Your brand may not have a similar configuration, but it's worth a look.
Frank and Eileen
No longer RVers or FR owners
Old 10-29-2014, 08:17 PM   #15
Flybob's Avatar
Try opening a cold water faucet to allow air to enter tank.
Old 10-30-2014, 08:03 AM   #16
dcheatwood's Avatar
No need to refill. Just add water while drain is open. Water going in should immediately come out.
drain, fresh water, tank, water, water tank
