Old 09-02-2014, 04:54 PM   #1
I wish I knew how to drain the fresh water tank.
I am brand new to this forum and to camping in a trailer. We are heading out tomorrow morning for our shakedown cruise.
The PDI indicated that the fresh water tank was full in our 2014 Apex 22qbc. I was shown the drain, and it is clearly marked on the side of the trailer.
I removed the black plug at the drain site. There was another one, and one coming directly from the tank. I removed all the plugs because I would get a steady stream for about 5 seconds, and then a dribble or nothing. I removed other of the plugs, some were black, some were almond colored. In all cases, the water is not coming out. All faucets are open. I tried the pump and the drainage was a little better, but I did not want to drain the battery, so I turned the pump off.
I think there is something special about the fitting these plugs were removed from. I did the low end plug, too. Same result. I do not want to carry all the extra weight tomorrow. I left the plugs out, but plan to put them back in tomorrow. How can I get the fresh water to drain? Thanks.
Gary
gmanharris is offline   Reply With Quote
Old 09-02-2014, 07:17 PM   #2
Send a message via Skype™ to chuckw5kav
Question, did you get any water out of the faucets when you had the pump on....If no
water out of the faucets then your
tank is already empty
2017 Durango Gold G384RLT
Coachmen Owners Association
2005 Ford F350 Dually
W5KAV
Last years Camping 125 days
This years Camping 150 an still going
chuckw5kav is offline   Reply With Quote
Old 09-02-2014, 07:30 PM   #3
Nope. The indicator was saying 3/4 full. I know they are not very accurate, but I'll bet that's it. Is there another to tell? Thanks.
Old 09-02-2014, 07:57 PM   #4
Well, lets see, if you have the drain open and no
water coming out and the water out of the faucets
than I'd bet it's empty... Form what I have seen
and read even the new trailer has problems at
time with the guages showing wrong for, water
black water and gray water tanks..Ugh
The only other way to see is to fill the tank
and the re-drain it that way you know it's
empty...Good luck
W5KAV
Old 09-02-2014, 08:02 PM   #5
Thanks. I can't think of anything else other than a faulty readout. Heading out tomorrow and will keep on learning.
Old 09-02-2014, 08:06 PM   #6
Kaadk's Avatar
If the water's been sitting for a while, it could be slime built up. Check out Herk's post in the dewinterizing FAQ for the instructions on how to sanitize that tank:
Going to dewinterize.
Steps 8-20
Old 09-02-2014, 10:13 PM   #7
WFD
I would be very surprised if your tank is full...I also think you have a faulty gauge...your dealer just looked at the gauge, saw it read 3/4 full and marked on your pdi that you had a full tank of water.....very rare that a dealer would give you your trailer with a full or even 3/4 tank of water...so many people dont want to haul their trailer with a full tank of water, and most people want to put their own water in from a known source....cant see the dealer filling it up.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 09-02-2014, 10:38 PM   #8
The only other way is to fill it and then dain it Ugh
W5KAV
Old 09-03-2014, 02:02 AM   #9
dcheatwood's Avatar
Obvious next step I'd take.
If water pump is running but no water coming out of faucets, tank is empty.
2018 Forester 3011 DS
Old 09-03-2014, 08:08 AM   #10
Mr. Dan's Avatar
You wrote "I removed the black plug at the drain site. There was another one, and one coming directly from the tank. I removed all the plugs...."
I'd like to see a picture of all these plugs/drains. I only have 1 drain line coming from my fresh water tank.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 09-03-2014, 03:18 PM   #11
dcheatwood's Avatar
In thinking low point hot and cold drains and fresh water drain.
Old 09-09-2014, 11:07 PM   #12
Soooooooooooooo have we found out, do we have Pictures I'm losing sleep over this
W5KAV
Old 09-09-2014, 11:19 PM   #13
GLCM Warrior
Lefty59's Avatar
When my gauges seem to be giving incorrect indications, I've had good luck in getting them back on track by disconnecting the battery (pull the battery disconnect on the Wildcat) and then pushing the button for the tank with the 'faulty' gauge indication. The lights usually flash momentarily and then when the battery is reconnected, the reading is correct. My last trip out my fresh water tank gauge was reading full even when my water pump was sucking air from an empty tank. Used this method and it fixed my issue.
Not sure why it works...just know that it does...at least for me.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 09-10-2014, 01:01 PM   #14
Anacortesians
Can you not actually see the tank to check the level? When we first got our Georgetown, there was no documentation showing where th FW tank was located. I finally tracked it down by listening to it fill.
It turned out that there are two cupboards down at floor level where the queen-size bed snugs up when the slide is retracted. For some daft reason, both were fastened closed by screws through the doors into the frame. I'd assumed they were dummy doors to look like the upper wardrobes. I took the screws out and opened the doors and there was the FW tank. There's actually a drain line going out to somewhere near the back bumper with a hand valve. Opening the valve drains the tank.
Your brand may not have a similar configuration, but it's worth a look.
Frank and Eileen
No longer RVers or FR owners
Old 10-29-2014, 08:17 PM   #15
Flybob's Avatar
Try opening a cold water faucet to allow air to enter tank.
Old 10-30-2014, 08:03 AM   #16
dcheatwood's Avatar
No need to refill. Just add water while drain is open. Water going in should immediately come out.
drain, fresh water, tank, water, water tank
