Old 12-23-2015, 09:49 PM   #1
Jensen audio system
This is our 2 time out in our new coachmen freedom express, we are unable to get Jensen audio system to turn on we have checked fuses tried to reset, there is no power at all to unit. Any help would be greatly appreciated, Merry Christmas!
Ladybugg747 is offline   Reply With Quote
Old 12-24-2015, 08:31 AM   #2
jensen system
You may need to remove the unit from the panel and insure all is "plugged in" at the rear of the system. Did you get a warranty with the RV unit? If you did, you may to return it perhaps with any other warranty issues.
Jim
jpaskell is offline   Reply With Quote
Old 12-24-2015, 08:54 AM   #3
KyDan's Avatar
I have no knowledge of your exact unit but it's not too uncommon to find
an inline fuse behind the unit. IF it were me- I'd pull out the unit and
check behind it for 12v at the incoming line.
You don't mention if it worked the 1st time you went out or if it worked
at the dealer when you bought it??
Doesn't matter much- check behind the unit and see what you find.
Good Luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 12-24-2015, 01:15 PM   #4
Converter not working
Took our coachman Liberty express out on 2 trip, battery not charging, lights very dim frig went over to gas, all outlets work, had to put slides in by crank, does this sound like converter went out, we are hooked up to 5o amp service still no charging, Jensen system not working either, did the test where u take line off battery still nothing ?? Any ideas on what is wrong, help!!
Old 12-24-2015, 01:25 PM   #5
The first time out the battery was dead and the dealership replaced it and everything worked fine including the Jensen unit, as the battery is not charging again am thinking the converter has gone out! Any thoughts? Merry Christmas!
Old 01-08-2016, 08:16 AM   #6
Converter had gone out, dealer replaced unit and all is good now
jensen
