Old 04-07-2016, 07:58 AM   #1
chaztrewhitt's Avatar
Jensen Customer Service
I have to give a "thumbs up" for Jensen. Called them, told them about a radio/dvd issue, they answered phone, spoke English, told me to send the head unit in and they will send me a replacement. Pretty good customer service. Thanks!
chaztrewhitt is offline   Reply With Quote
Old 04-08-2016, 12:08 PM   #2
That is good news. Thanks for sharing
2016 Coachmen Freedom Express Liberty Edition 292BHDS
FRRVR is offline   Reply With Quote
Old 04-12-2016, 08:02 AM   #3
test
2016 APEX 279RLSS
Towing with:
2016 Chevy 1500 5.3 Beast / w/ 3.73
1968 Chevy C10 5.7 w 3.73
Old 04-12-2016, 02:54 PM   #4
Commercial Member
Hi chaztrewhitt,
We appreciate you taking the time and effort to share your positive experience here on Forest River Forums. I'm sorry you had difficulty with your DVD player, however, I'm glad to hear we were able to assist you. Don't hesitate to contact us again if you need anything else!
ASA Electronics - Producer of JENSEN RV TV's, stereos & speakers; Voyager Observation Systems & Advent appliances.
jensenrvdirect
JENSENRVDirect is offline   Reply With Quote
Old 04-20-2016, 12:23 PM   #5
Finally found time to send head unit to Jensen, as promised, a new one was returned within 5 days. Double checked everything on the TT and installed the new head unit, works like new.
thanks!
tt
2016 APEX 279RLSS
Towing with:
Old 04-20-2016, 04:48 PM   #6
Gotta love stories like this.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is offline   Reply With Quote
Old 05-08-2016, 11:01 AM   #7
Originally Posted by JENSENRVDirect View Post
Hi chaztrewhitt,
Good day,
I have a 2014 salem travel with a Jensen radio,stereo system in it. I can not receive any am or fm radio stations while I can in my truck and can while sitting right next to it. Seems as though there is not an antenna hooked up to it!
Is there something I can do or add to rectify this issue. Thanks
2014 Salem 27RKSS
Burgeogull is offline   Reply With Quote
Old 05-08-2016, 12:23 PM   #8
I would bet your antenna cable is loose. You should be able to gain access by a side panel or just remove the 4 screws on front and plug the antenna cable back in.
2016 APEX 279RLSS
Towing with:
Old 05-09-2016, 07:10 AM   #9
Commercial Member
Hi Burgeogull,
Yes, if you do not receive any stations then most likely the antenna is disconnected, loose or damaged. As chaztrewhitt suggested, remove the four screws to allow you to pull the unit from the wall and gain access to the rear and you can check the antenna connection.
If the antenna is secured to the radio, you may need to do some further diagnostics on the antenna. Some applications may have a FM signal booster. If your coach does, you will need to verify this is connected properly and is functional. Your RV dealer should be able to assist in determining what components are installed on your coach.
If you have any questions or need further assistance, please call our Technical Services dept at 877-845-8750 M-F 8:00AM to 6:00PM EDT and they will be happy to answer any specific questions you may have.
jensenrvdirect
customer service, jensen, service
